[TBC][BUG] Inconsistent behaviour of unconstrained elements detector in Sketcher
PrzemoF
Postby PrzemoF » Wed Apr 07, 2021 6:07 pm
The video shows the problem: https://peertube.social/videos/watch/d5 ... a1b15e33bf
How to recreate:
1. Create new document, new sketch
2. Create line, circle
3. Activate the function
4. Line/circle is not selected
When the circle center is fixed the detection works as expected.
Some other problems are showing up as well with more complicated shapes:
Zrzut ekranu z 2021-04-07 19-04-26.png (159.92 KiB) Viewed 222 times
Re: [BUG] Inconsistent behaviour of unconstrained elements detector in Sketcher
Postby chrisb » Wed Apr 07, 2021 9:12 pm
Works here as expected. Invoking Select unconstraint DoF works with the link in the message, the icon and the menu.
OS: macOS 10.16
Version: 0.20.24612 (Git)
Hash: f525904c1be10a0f55aa3502151c2c55e5054259
Python version: 3.9.2
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
Locale: C/Default (C)
PrzemoF
Postby PrzemoF » Wed Apr 07, 2021 9:15 pm
Interesting... I can't repeat it after closing FreeCAD...
OS: Fedora 33 (Workstation Edition) (GNOME/gnome-xorg)
Version: 0.20.24690 (Git)
Hash: 3a36602ae8252e278a5322c765eeb1f8c6bd93ff
Qt version: 5.15.2
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
PrzemoF
Postby PrzemoF » Wed Apr 07, 2021 9:47 pm
OS: macOS 10.16
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
Can you draw a rectangle and test the function?
Postby chrisb » Wed Apr 07, 2021 10:04 pm
Sketch with Line, Rectangle, Circle: they are all selected correctly on clicking the link.
PrzemoF
Re: [TBC][BUG] Inconsistent behaviour of unconstrained elements detector in Sketcher
Postby PrzemoF » Fri Apr 09, 2021 8:53 pm
OK, it's getting interesting..
The fedora 33 FreeCAD:
Version: 0.19.Unknown
Build type: Unknown
Python version: 3.9.0
Qt version: 5.15.1
OCC version: 7.5.0
Zrzut ekranu z 2021-04-09 21-44-30.png (142.3 KiB) Viewed 113 times
My local build:
Qt version: 5.15.2
OCC version: 7.5.0
Zrzut ekranu z 2021-04-09 21-45-50.png (154.48 KiB) Viewed 113 times
Can I kindly ask other people to perform simple test:
1. New drawing, new sketch
2. Draw rectangle
3. Click this function:
Zrzut ekranu z 2021-04-09 21-47-42.png (77.38 KiB) Viewed 113 times
4. Post the screen shot of the result
Postby chrisb » Fri Apr 09, 2021 9:56 pm
Here you are:
I can imagine, that this depends on the exact position of the rectangle. To make this comparable you should save the file and test it on different systems.
Do you use the same solver?
PrzemoF
Postby PrzemoF » Sat Apr 10, 2021 11:35 am
Thanks! I didn't touch the settings, so I guess it's the same solver. I'll check that to be sure.
Edit: the problem is solver independent.
Postby chrisb » Sat Apr 10, 2021 12:22 pm
Can you upload the file that leads to the two-lines-proposal?
PrzemoF
Postby PrzemoF » Sat Apr 10, 2021 4:35 pm
Just to let you know - the file gives 4 points when I open it in my local build FreeCAD, so it's definitely problem with the official fedora build.
2line.FCStd
(7.67 KiB) Not downloaded yet
cron
