[TBC][BUG] Inconsistent behaviour of unconstrained elements detector in Sketcher
The video shows the problem: https://peertube.social/videos/watch/d5 ... a1b15e33bf
How to recreate:
1. Create new document, new sketch
2. Create line, circle
3. Activate the function
4. Line/circle is not selected
When the circle center is fixed the detection works as expected.
Some other problems are showing up as well with more complicated shapes:
How to recreate:
Re: [BUG] Inconsistent behaviour of unconstrained elements detector in Sketcher
Works here as expected. Invoking Select unconstraint DoF works with the link in the message, the icon and the menu.
OS: macOS 10.16
Version: 0.20.24612 (Git)
Hash: f525904c1be10a0f55aa3502151c2c55e5054259
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: C/Default (C)
Interesting... I can't repeat it after closing FreeCAD...
OS: Fedora 33 (Workstation Edition) (GNOME/gnome-xorg)
Version: 0.20.24690 (Git)
Hash: 3a36602ae8252e278a5322c765eeb1f8c6bd93ff
Qt version: 5.15.2
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
Qt version: 5.15.2
OCC version: 7.5.0
Can you draw a rectangle and test the function?chrisb wrote: ↑Wed Apr 07, 2021 9:12 pmWorks here as expected. Invoking Select unconstraint DoF works with the link in the message, the icon and the menu.
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.1
Sketch with Line, Rectangle, Circle: they are all selected correctly on clicking the link.
Re: [TBC][BUG] Inconsistent behaviour of unconstrained elements detector in Sketcher
OK, it's getting interesting..
The fedora 33 FreeCAD:
Version: 0.19.Unknown
Build type: Unknown
Python version: 3.9.0
Qt version: 5.15.1
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL) My local build:
Qt version: 5.15.2
OCC version: 7.5.0
Can I kindly ask other people to perform simple test:
1. New drawing, new sketch
2. Draw rectangle
3. Click this function: 4. Post the screen shot of the result
Build type: Unknown
Qt version: 5.15.1
OCC version: 7.5.0
Qt version: 5.15.2
OCC version: 7.5.0
2. Draw rectangle
Here you are:
Do you use the same solver?
I can imagine, that this depends on the exact position of the rectangle. To make this comparable you should save the file and test it on different systems.Do you use the same solver?
Thanks! I didn't touch the settings, so I guess it's the same solver. I'll check that to be sure.
Edit: the problem is solver independent.
Can you upload the file that leads to the two-lines-proposal?
Just to let you know - the file gives 4 points when I open it in my local build FreeCAD, so it's definitely problem with the official fedora build.
- 2line.FCStd
- (7.67 KiB) Downloaded 7 times
