[bug] Cant add reference constraint to already defined circle/arc
abdullah
Re: [bug] Cant add reference constraint to already defined circle/arc
Post by abdullah »
openBrain wrote: Sun Jun 13, 2021 6:24 pm
chrisb wrote: Fri Jun 11, 2021 10:13 pm Great addition. For me all three options are an improvement. For keeping as much as possible in its current state I would go for option 1 or 3.
abdullah wrote: Sat Jun 12, 2021 5:14 am I like it. Merged. Thanks. :D
1 or 3 is ok with me. In addition, you may make the new tool the initial default (before the new parameter has a given value).
Thx guys. I implemented option 3. ;) Pull request is here along with a bugfix for the previous PR => https://github.com/FreeCAD/FreeCAD/pull/4861
I found the "-1" in:
"int curRadDiaCons = hGrp->GetInt("CurRadDiaCons", -1);"
misleading for a code reader.
I see that the switch/case will filter this via "default", but still it is unexpected.
openBrain
Post by openBrain »
abdullah wrote: Sat Jun 19, 2021 6:31 am I found the "-1" in:
Humm. In my own programming paradigm, this is quite standard for 'undefined' (among other depending on the context). :? I'm not against changing that but can't think about something I'm sure is better. May you have a proposal?
Edit : not trying to convince but see how -1 is often found in Qt for similar meaning : https://doc.qt.io/qt-5/qtabbar.html#currentChanged
abdullah
Post by abdullah »
openBrain wrote: Sat Jun 19, 2021 8:52 am
What about "2"?
If I am understanding it correctly, we want that when the parameter does not exist, it defaults to "2" i.e. your improvement.
As I see it, we do not want to default it to "undefined", we want to default it to "your method". Am I not seeing something?
openBrain
Post by openBrain »
abdullah wrote: Sat Jun 19, 2021 11:32 am What about "2"?
'2' will functionally do the same ATM. My idea was to be more generic in case there is an evolution in the future. ;)
I can update the PR in the coming hours if you think '2' is the way to go. ;) Just tell me.
Edit : just saw you already merged. So I can create a new PR to change if needed, or of course you can feel free to do it by yourself. :)
abdullah
Post by abdullah »
openBrain wrote: Sat Jun 19, 2021 11:49 am
How I see it is that no matter where we might be heading in the future, we need a default value, which may be the current one or another one. I am happier with the parameter taking a value that is valid within the code, because the code shows this intent.
It was not my idea to have you change just one value. I did not merge it in the morning because I still had to compile it and run it and I was running out of time. I have now added a commit making the default '2'.
Thanks for the code :)
openBrain
Post by openBrain »
abdullah wrote: Sat Jun 19, 2021 12:01 pm It was not my idea to have you change just one value. I did not merge it in the morning because I still had to compile it and run it and I was running out of time. I have now added a commit making the default '2'.
I'm very fine with having a shepherd for FC code and having my code reviewed. :) And I'm fine with just having to change a single value too. Finally it means my code was pretty good. :lol:
Thanks for the merge. I'll go for the documentation now. :)
openBrain
Post by openBrain »
Documentation is now available : Sketcher ConstrainRadiam
I also fixed in documentation multiselection behavior that was changed by 1st PR of this topic regarding arcs/circles.
