[BUG?] [App::Link] Partial Document Loading Issue (Link not restored) in 19.1
gbroques
Postby gbroques » Fri Apr 09, 2021 12:18 am
Can anyone please help me with what seems to be a partial document loading issue in my project?
  • Any common gotchas that can cause a link to not be restored?
  • Any common fixes for a non restorable link?
See the below screenshot and Steps to Reproduce.
realthunder wrote:
REPORT VIEW
19:06:53 <PropertyLinks> PropertyLinks.cpp(2646): object 'Body' not found in document 'Flange'
19:06:53 1.119e-06 <App> Document.cpp(2857): Hub#Link.LinkedObject: Link not restored
Linked object: Body
Linked document: Flange
19:06:53 0.237285 <App> Document.cpp(2855): Alternator#Link.LinkedObject: Time stamp changed on link Hub#Part
STEPS TO REPRODUCE I can manually fix this by:
  • Double-clicking the document where the link was not restored (i.e. Flange.FCStd).
  • Going back to the document with the non restored link and recomputing the object containing the link (i.e. recompute Hub in Alternator.FCStd).
However, I have requirements that this needs to be automatically loaded without manual user intervention.
FREECAD ABOUT
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.24276 (Git) AppImage
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
gbroques
Re: [App::Link] Partial Document Loading Issue in 19.1
Postby gbroques » Fri Apr 09, 2021 12:56 am
I've seemed to have fixed this problem and found a workaround (checkout commit 2b542c0f23ab105063).
The problem seemed to be caused by a document (Alternator) containing two references to a child document (Flange) -- where each of the two references were to two different objects:
  • The first reference is a direct reference to a spreadsheet in Flange from the spreadsheet in Alternator.
  • The second reference is a indirect reference via a direct Link to Hub, and Hub links to a body in Flange (which is the link that fails to restore).
Note, Flange is not an immediate child of Alternator.
The document relationship hierarchy is:
Alternator -> Hub -> Flange
I fixed this by removing the following reference in the spreadsheet to the Flange document, and instead hardcoding MiddlePadThickness in the Alternator spreadsheet (see below before and after screenshots).
Is this a bug, or expected behavior?
BEFORE FIX
AFTER FIX
realthunder
Re: [BUG?] [App::Link] Partial Document Loading Issue in 19.1
Postby realthunder » Sat Apr 10, 2021 1:45 am
This looks like a bug if file dependency calculation. Thanks for the detailed report. I'll fix it soon.
gbroques
Postby gbroques » Sat Apr 10, 2021 2:43 pm
realthunder wrote: Sat Apr 10, 2021 1:45 am This looks like a bug if file dependency calculation. Thanks for the detailed report. I'll fix it soon.
Thanks for taking a look! Your drive to improve FreeCAD and willingness to help others is commendable and exceptional sir! :D
I made an initial attempt to recreate this with a minimal example, but was unable to.
Thus, I'm not exactly sure what combination of factors created the "Link not restored" issue.
I know you're busy with many other things, so feel free to put your foot down and say that you need a minimal example pin-pointing the exact cause of the "bug". I understand completely.
Of course, if you're willing to take a look at my complex example. I appreciate it! 🥳
