Hello!
Works here flawless:
OS: Debian GNU/Linux bullseye/sid (X-Cinnamon/lightdm-xsession)
Version: 0.20.24692 (Git)
Build type: Debug
Hash: 4e4068e44f4df06f352543c679da9079d1ffcb67
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.1
and
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa XT [Radeon PRO WX 3100]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Lexa XT [Radeon PRO WX 3100]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
Note: i use amdgpu not radeon. Check what you use (l
spci -k). I had also issues with radeon, but not on FreeCAD.
Here the log from open the file:
Log: 49.0008 MainWindow.cpp(1316): update actions
Log: Active view is Unnamed : 1[*] (at 0x7f57100088a0)
Log: Active document is Lower_test (at 0x55813420ae40)
Log: 71.9417 Tree.cpp(803): delay update status
Log: 71.9435 Tree.cpp(803): delay update status
Log: 71.9469 Tree.cpp(803): delay update status
Log: ViewProvider update time: 0.005000 s
Log: Shape tria info: Faces:0 Edges:8 Nodes:39 Triangles:0 IdxVec:39
Log: ViewProvider update time: 0.004000 s
Log: <Gui> ViewProviderDocumentObject.cpp(220): Lower_test#Sketch001.ViewObject.DiffuseColor changed
Log: <App> Application.cpp(776): Lower_test restore time: 0.0882454s
Log: <App> Application.cpp(777): Lower_test postprocess time: 0.00171449s
Log: <App> Application.cpp(779): total time: 0.090828s
Log: 72.098 Tree.cpp(2349): begin update status
Log: 72.0988 Tree.cpp(4418): [TreeView] Create item: 1, Lower_test#Sketch
Log: 72.0996 Tree.cpp(4418): [TreeView] Create item: 2, Lower_test#Sketch001
Log: 72.1002 Tree.cpp(4418): [TreeView] Create item: 3, Lower_test#Sketch002
Log: 72.1004 Tree.cpp(2410): update item status
Log: 72.1007 Tree.cpp(2504): done update status
Log: 72.1011 MainWindow.cpp(1316): update actions
Log: 72.2546 MainWindow.cpp(1316): update actions
Here the log from
Sketch:
Log: Active view is Lower-test : 1[*] (at 0x7f57100088a0)
Log: 101.554 MainWindow.cpp(1316): update actions
Log: 102.393 Selection.cpp(1108): Add Selection Lower_test#Sketch. (0, 0, 0)
Log: 102.553 MainWindow.cpp(1316): update actions
Log: <Gui> Document.cpp(331): deduced editing reference Lower_test#Sketch.
Log: 102.577 Selection.cpp(1609): Clear selection
Log: <Gui> ViewProviderDocumentObject.cpp(220): Lower_test#Sketch.ViewObject.TempoVis changed
Log: 102.85 Tree.cpp(803): delay update status
Log: Sketcher::setUpSketch()-T:0.018
Log: 102.998 Tree.cpp(803): delay update status
Log: Sketcher::Solve()-DogLeg-T:0.001
Log: 103.005 Tree.cpp(803): delay update status
Log: 103.012 Tree.cpp(803): delay update status
Log: 103.061 Tree.cpp(2349): begin update status
Log: 103.061 Tree.cpp(2410): update item status
Log: 103.062 Tree.cpp(2504): done update status
Log: 103.062 MainWindow.cpp(1316): update actions
Here the log from
Sketch002:
Log: 162.6 MainWindow.cpp(1316): update actions
Log: <3DViewer> View3DInventorViewer.cpp(883): add annotation 4 Sketch002.
Log: 164.873 Selection.cpp(1609): Clear selection
Log: 164.874 Selection.cpp(1108): Add Selection Lower_test#Sketch002. (0, 0, 0)
Log: 165.017 MainWindow.cpp(1316): update actions
Log: <Gui> Document.cpp(331): deduced editing reference Lower_test#Sketch002.
Log: 165.057 Selection.cpp(1609): Clear selection
Log: 165.08 Tree.cpp(803): delay update status
Log: Sketcher::setUpSketch()-T:0.012
Log: 165.147 Tree.cpp(803): delay update status
Log: 165.149 Tree.cpp(803): delay update status
Log: 165.154 Tree.cpp(803): delay update status
Log: 165.18 Tree.cpp(2349): begin update status
Log: 165.18 Tree.cpp(2410): update item status
Log: 165.181 Tree.cpp(2504): done update status
Log: 165.204 MainWindow.cpp(1316): update actions
Greetings
user1234
