Invisible Edges invisible
Greetings. How come these Finnys don't show up as dotted lines in Techdraw View?
I have followed the instructions to-the-letter, and wiggled every false-true I could find, but the TechDraw views never change, show no effects.
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Thamks.
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Thamks.
- Fanny.FCStd
- (61.44 KiB) Downloaded 18 times
Re: Invisible Edges invisible
Which instructions?
Set HardHidden to true. You may have to select a darker color to see the hidden lines.
Is this what you are looking for?
If so think you selected bottom of fan and inserted as view in your drawing.
Just a guess.
Just a guess.
- fanny.jpg (55.48 KiB) Viewed 752 times
Up date I clicked on your view and changed settings and recompute and it shows the hidden lines below what I think is fan base.
Another option.
Remember for some settings to take effect you may have to hit the recompute button.
Another option.
- fanny 2.jpg (68.83 KiB) Viewed 744 times
There is the Basic TechDraw Tutorial, there are many forum posts, there are video tutorials, ...
A bit more specific by giving a link would be helpful; either to see it's all there, or to improve the documentation.
Good to see you got it solved.
I had meant you should have given a link to the corresponding wiki page, when talking about "instructions in the TechDraw manual" or the "instructions to-the-letter".
That makes it easy to have a look at the documentation and correct or extend it if necessary, while I can say for myself that I will not read through all the TechDraw pages to search for what you are talking about.
I have not yet solved the riddle of how to insert a link to external articles or even other Forum Topics. Trouble Navigating the Forum. If I leave this Window to find a Quote, I ofttimes can't get back, if I save a Draft, I don't know how to re-open it except by Poke-and-Hope, which has never worked the same way twice.
This is the first Forum I have ever participated, and I am basically groping in the dark, amid a sea of swirling buzz-words, technical jargon, buttons of mysterious function that sometimes take me far astray and lose everything I just typed. It took me 3 tries to post the "Tree View Management' question, and I discovered some old Drafts I had thought were long ago Posted and forgotten.
I can't find any literature about navigating Forums in general, nor this one in particular.
One problem is, your good-hearted and helpful Team uses words and concepts that should be meaningful to Everyone, except I've been out-of-touch and never heard of them before. I can understand a lot of things, but some things are just completely meaningless, like strings of nonsense words. For example, saying 'give a link' would be much more meaningful if I had more than a vague idea of what a 'link' is, and knew the steps needed to give one, but when I explore it, I go farther and farther astray, and no matter how I structure my Search Queries, I am smothered by thousands of unrelated articles and very rarely pull up anything remotely helpful. I just cringe when people suggest looking through the Forum for help, because every time I try, I just spend sometimes hours flipping through Query returns that do not relate to my intended Query in any way, and then end up posting a question anyway.
So, yes, I would love to insert a link. How is this accomplished?
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
A link in the forum sense is something you can click on and which leads you to another web page; thus it links the pages. When I ask for a link I mean you copy the so called internet address also known as uri, which has in case of the wiki the form of https://wiki.freecadweb.org/.... Then you insert this into the text of your post.
You can play with the forum posts, if you use the Preview button, so you don't create garbage in the forum.
