How do I get started making parts?
ChrisNelson
Re: How do I get started making parts?
Postby ChrisNelson » Fri Apr 16, 2021 1:04 am
ChrisNelson wrote:
Fri Apr 16, 2021 12:54 am
Bance wrote:
Thu Apr 15, 2021 11:15 pm
You should probably fuse the parts into a single solid first.
Somehow I bumbled around until I found how to fuse then I was able to clone. Thanks, all!
ChrisNelson
Postby ChrisNelson » Mon Apr 19, 2021 12:54 am
So, if I now want to revised the fused part, how do I un-fuze it? I had to use "union" to "fuse" so I'm really not sure what name to be looking for. Thanks.
Bance
Postby Bance » Mon Apr 19, 2021 6:24 am
Just go to the part in the tree and change it, everything should adjust after.
Post your file, its awfully hard to see what you've done to offer any advice.
ChrisNelson
Postby ChrisNelson » Tue Apr 20, 2021 12:11 am
Sorry. I'm so used to working with huge files that posting documents to a forum like this feels wrong.
I want to add another piece to Tool Base. But that now seems to have no components so, I guess I want to modify "Fusion" in the tree.
Tool Cabinet.FCStd
(49.35 KiB) Downloaded 4 times
Bance
Postby Bance » Tue Apr 20, 2021 12:20 am
I don't understand what it is you want.
If I modify E.G. the depth of the panel, "core" from 19.05 to 12 it updates in fusion and both clones!
ChrisNelson
Postby ChrisNelson » Tue Apr 20, 2021 12:50 am
No. I want to add a "cleat" down the middle of the core, a six cube as part of the subassembly.
Bance
Postby Bance » Tue Apr 20, 2021 6:29 am
Form the cleat then fuse it with Fusion(better use some names here.)
Note you will have to delete and remake the clones, unless the cleat connects to them as a single object, then fuse them with it.
Make sense?
Postby chrisb » Tue Apr 20, 2021 11:09 am
If you don't only want to change a property of one of the components, but add, remove or exchange a complete object, you can use the "Shapes" property. Click at the button to the right and select the objects.
ChrisNelson
Postby ChrisNelson » Tue Apr 20, 2021 11:26 pm
Make sense?
Yes. Thanks. I'll give it a try.
Bance
Postby Bance » Wed Apr 21, 2021 7:39 am
Chris is this documented anywhere, I'm struggling to find it.
