Cross document expression, relocate main file
hreintke
Post by hreintke »
Learning how to use cross document expressions.
What I have now.
- Main file LegoDimensions which includes a spreadsheet with basic brick and beam dimensions-
- Testfile, LegoDimensionsTest which uses Part design to create a specific brick.
The Testfile uses the LegoDimensions spreadsheet.
Question is about the absolute path name of the Main file used for the cross linking in the Testfile.
When I move the Main LegoDimensions to another directory, Opening the testfile gives an error,
13:08:21 Exception opening file: C:/Userdata/Lego/Freecad/LegoDimensions.FCStd [File 'C:/Userdata/Lego/Freecad/LegoDimensions.FCStd' does not exist!]
Which of course is correct.
I tried opening the LegoDimensions main file from the new location, then opening the LegoDimensionsTest but that gives the same error.
Is there a way that I can update the path in the Testfile so that is uses the new file location of the Main file ?
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/Netherlands (en_NL)
LegoDimensionsTest.FCStd
(9.42 KiB) Downloaded 23 times
(2.03 KiB) Downloaded 26 times
Roy_043
Re: Cross document expression, relocate main file
Post by Roy_043 »
hreintke wrote: Tue Apr 13, 2021 11:41 am Is there a way that I can update the path in the Testfile so that is uses the new file location of the Main file ?
Actually the path to the LegoDimensions.FCStd file is not stored in the LegoDimensionsTest.FCStd file. If you open the LegoDimensions.FCStd file first all cross document expressions should work and you can just ignore the warning.
JeffWorley
Post by JeffWorley »
Roy_043 wrote: Sat Apr 17, 2021 1:33 pm
Does this imply that in the formula editor, the path to the other file does not matter at all?
When I cross-link to a spreasheet (in FreeCAD 0.19) in a file named "thisFile" in the formula editor I have something like
=<<otherFileName>>#<<spreasheetLabel>>.CellAlias
So I could open any file of name "otherFileName" that contains a spreadsheet with label "spreadsheetLabel" before I open "thisFile" and "thisFile"'s formula editor will resolve the formulas as defined by the specific "otherFileName" we opened?
I ask this because I've observed behavior where when I open "thisFile" it will load "otherFileName" but it's greyed out (so I assume not actually opened yet). Once I double-click on the greyed-out "otherFileName" the file I expect to open will open. How could this happen if there is no pathname (absolute or relative) associated with the <<otherFileName>># resolution?
This is important to me because a project I'm currently working on will change depending on whether this cross-linked file is referenced via absolute paths, relative paths, or just by whichever document is open that matches the file name. I'm very new to FreeCAD so sorry in advance for my lack of knowledge!
Thank you!
Roy_043
Post by Roy_043 »
You are correct, the relative path to the referenced file is stored in V0.19. I must have had the V0.18 behavior in mind when I wrote my previous message. The path to the LegoDimensions.FCStd file is missing, but in V0.19 this means that the referenced file is in the same folder.
JeffWorley wrote: Tue Jan 11, 2022 1:53 am I ask this because I've observed behavior where when I open "thisFile" it will load "otherFileName" but it's greyed out
There is a strange thing with this behavior: This does happen for PartDesign Bodies that reference the external spreadsheet, but not if you have a file with only a Part_Box that references the same external data.
JeffWorley
Roy_043 wrote: Tue Jan 11, 2022 9:04 am the relative path to the referenced file is stored in V0.19. ... The path to the LegoDimensions.FCStd file is missing, but in V0.19 this means that the referenced file is in the same folder.
Thank you, your answer solves a lot of problems for me!
