Sketch lines all go black
tre4b
Postby tre4b » Tue Apr 13, 2021 9:19 pm
I'm using 0.19
OS: Windows 10 (10.0)
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.8
Qt version: 5.12.5
OCC version: 7.4.0
Every now and again when I am doing a sketch all the lines and points change colour to black. Going out and back in to the sketch puts them back to normal. Am I doing something that can easily be reversed by mistake or is this a bug I should report?
Re: Sketch lines all go black
Postby chrisb » Tue Apr 13, 2021 11:04 pm
tre4b wrote: Tue Apr 13, 2021 9:19 pm Am I doing something that can easily be reversed by mistake or is this a bug I should report?
Neither of these. I remember Werner saying that something is running out of resources. Reopening sketcher or even restarting FreeCAD usually helps.
tre4b
Postby tre4b » Thu Apr 15, 2021 7:46 am
Ta Chris, that was what I found going out and in again clears it up.
This computer has 12 cores and 64gb Ram though so not sure what resources it needs ;-) Is the code base 32bit?
Trev
Postby chrisb » Thu Apr 15, 2021 9:04 am
tre4b wrote: Thu Apr 15, 2021 7:46 am This computer has 12 cores and 64gb Ram though so not sure what resources it needs ;-) Is the code base 32bit?
As you can see from your FreeCAD infos, you use a 64-bit FreeCAD. I don't think it is the hardware resources, it is rather something in one of the used libraries such as Qt (I don't know which library finally handles Sketcher's 3D view).
bambuko
Postby bambuko » Thu Apr 15, 2021 10:40 am
tre4b wrote: Thu Apr 15, 2021 7:46 am ...
I had the same problem on similar machine (occasionally) and the solution was the same, so glad that it isn't only me ;)
As for the cores... apparently it is CPU clock speed that matters more than a numebr of cores, for 3D CAD work:
https://www.cgdirector.com/best-compute ... rendering/
openBrain
Postby openBrain » Thu Apr 15, 2021 10:54 am
This has been reported in French subforum by several users but we never could narrow down what causes this issue... Maybe Coin or OpenGL
tre4b
Postby tre4b » Thu Apr 15, 2021 12:04 pm
Yeah it is really random. When it starts happening it keeps on doing it but most days it does not ever happen. I've not even been able to workout what I was doing just before. If I ever do I will report it. Otherwise its just one of them wrinkles I'm more than happy to pay for a program I'm enjoying ;-)
openBrain
Postby openBrain » Thu Apr 15, 2021 1:15 pm
I'm happy there is now a thread in the main subforum, but I'm afraid there is indeed much we can do while we have no way to reproduce the issue. :)
LHC
Postby LHC » Fri Apr 16, 2021 2:13 am
Another user here that's experienced it. Glad I'm not alone at least ! If it happens to me in any sort of repeatable fashion I'll report but by the sounds of it this is an elusive creature.
