scaling
drmacro
Re: scaling
Post by drmacro »
degarb wrote: Thu Apr 22, 2021 10:45 pm design. Opened a body, created a sketch, but cant draw on it because of a parameter dialiog where nothing seem to be documented or is able to dismiss or click anything.
with an open sketch, you click the line icon (it's white with red dots on each end) and then click at 2 places. BAM there's a line.
can you post a picture this "parametric dialog".
...and try reading, at least, the first pdf in the link in my signature below.
degarb
Re: scaling
Post by degarb »
I open part design, new body then new sketch. I can’t draw anything.
“Invalid selection: There are no attachment modes that fit selected objects. Select something else. “ Then a Point Parameters task dialog .
I am only getting this error in 1.9, not 1.7. I can draw as normal in 1.7 in part design, at this stage in my exploration of freecad.
Sketcher everything is greyed out, in 19
edwilliams16
Re: scaling
Post by edwilliams16 »
degarb wrote: Thu Apr 22, 2021 11:47 pm “Invalid selection: There are no attachment modes that fit selected objects. Select something else. “
If you select something prior to opening a sketch, FreeCAD figures you want to attach the sketch to it somehow. If it makes no sense to attach to what you have selected, it will give the error.
If you just do what you said: start a document, go to Part Design, create a body, create a sketch, then you'll get a dialog asking what plane you want to sketch on. If that doesn't happen, you're installation is seriously screwed up.
Re: scaling
Please don't spread your posts all over the place: https://forum.freecadweb.org/viewtopic.php?f=3&t=58029
