Pan an Rotate hotkeys not working
Hi, I have recently installed FreeCAD's new release 0.19. But the hotkeys alt(to rotate the model) and shift (for pan) are not working. whereas I have alt is working in my system, I have checked it using alt+tab. Shift also worked in FreeCAD when I used it to create trash. But these two (alt and shift) not worked for rotation and pan. kindly help.
Re: Pan an Rotate hotkeys not working
Welcome to the forum!
Read the banner at the top of the page.
What navigation mode do you use?
I have gone through the forum, but couldn't find a relevant solution. I am manually using the navigation commands.
Which Mouse Model are you using?
He's not!
OK, so your read point 3, what about point 4? If there is a bug we need to know the details of your systemManpreet227 wrote: ↑Sun Apr 25, 2021 7:55 am I have gone through the forum, but couldn't find a relevant solution. I am manually using the navigation commands.
Can you try to give step by step description how to reproduce the problem? I read your initial post 3 times and I'm not sure if I understand what's wrong.
Panning with cursor doesn't work?
On my system:
- cursor - pan the model
- alt+cursor - pan the model
- shift + cursor left/right - rotate
- shift+up/down - pan
My systems:
OS: Fedora 33 (Workstation Edition) (GNOME/gnome-xorg)
Version: 0.19.Unknown
Build type: Unknown
Python version: 3.9.0
Qt version: 5.15.1
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
and
Version: 0.20.24753 (Git)
Hash: a76fb2c6d69dd7fb8fe9bc96d4f756f704325f73
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.0
