Start a sketch makes view upside down
I thought it was a bit unusual that if I make a sketch of the rear of an object, the sketcher makes the view upside down. Is there anyway to disable this? I went through the display preferences and could not find something.
Maybe it is useful and I just don't understand how it is superior than always having up as up.
Re: Start a sketch makes view upside down
Woefully short of information, to even comment.
Guessing you have your sketch attached to something - the Map Reverse parameter in the Data panel will do what you want.
Whatever direction upside down applies to: you may turn the attachment offset by 180° around z.
Exactly. Around which axis to rotate depends on what exactly upside down means.edwilliams16 wrote: ↑Fri Apr 30, 2021 8:52 pm I think you meant to say rotate by 180 about the x- or y-axis. The local z-axis of a sketch is normal to it, so rotating around z just spins the sketch around.
Buuuuuuut what if its downside uuuup?
Rotating each time you open sketch is not just annoying, but also place all shown dimension upside down (or downside up).
Is such reversion done by design?
- thomas-neemann
is this a solution for you?
https://www.youtube.com/watch?v=GzWEVJ0Rp18
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 2022.709.28846 (Git) AppImage
Branch: LinkStage3
Hash: c880c050c5f7601e4bae6740de71500edf2be0c7
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Looks great!
How did you achieve this?
