How many Bodies
dwehm1
How many Bodies
Postby dwehm1 » Sat May 01, 2021 3:20 pm
Hi everyone, I have a quick question, I am designing one sketch. It seems like I get an error a lot in Part design when I try the Fillet. Some thing along the lines of "not part of an active body"
drmacro
Re: How many Bodies
Postby drmacro » Sat May 01, 2021 4:02 pm
In Part Design the sketch has to be in the active body.
Normally, when you switch to Part Design workbench and click the new sketch icon, if there is a active Body, the sketch is created in the Body.
If there is no active Body, then one is created and the sketch is added to it.
My beginners, written treatise: Learning FreeCAD
thomas-neemann
Re: How many Bodies
Postby thomas-neemann » Sat May 01, 2021 4:56 pm
dwehm1 wrote: Sat May 01, 2021 3:20 pm Hi everyone, I have a quick question, I am designing one sketch. It seems like I get an error a lot in Part design when I try the Fillet. Some thing along the lines of "not part of an active body"
the realthunder version can handle several parts.
falls ein video-link von mir schwarz und nicht anklickbar sein sollte, hier der kanal: https://www.youtube.com/channel/UCVcztV ... 03GgKekj_g
es ist auch möglich auf antworten zu klicken um den link zu sehen.
Re: How many Bodies
Postby chrisb » Sat May 01, 2021 5:30 pm
Adding to drmacro, you cannot use the PartDesign fillet dressup to fillet a sketch. It can only fillet solids. To include the fillets in the sketch you have to edit the sketch.
Re: How many Bodies
Postby chrisb » Sat May 01, 2021 5:31 pm
thomas-neemann wrote: Sat May 01, 2021 4:56 pm the realthunder version can handle several parts.
Can it fillet sketches in PartDesign?
thomas-neemann
Re: How many Bodies
Postby thomas-neemann » Sat May 01, 2021 5:56 pm
chrisb wrote: Sat May 01, 2021 5:31 pm
I do not know that. I am referring to it here
https://forum.freecadweb.org/viewtopic. ... 32#p500400
"Realthunders Version kann mit mutliple solids umgehen."
Re: How many Bodies
Postby chrisb » Sat May 01, 2021 6:07 pm
What has it to do with OPs question?
thomas-neemann
Re: How many Bodies
Postby thomas-neemann » Sat May 01, 2021 6:27 pm
chrisb wrote: Sat May 01, 2021 6:07 pm What has it to do with OPs question?
if i understand correctly i have answered the question. if i got it wrong i delete my answers
Modeler
Re: How many Bodies
Postby Modeler » Wed May 05, 2021 3:39 am
I assume you have multiple bodies in your drawing. If you select an object from an inactive body and try to fillet it the program will give an error. If you only have 1 body but it is not active the same thing will happen.
Select the body you want to fillet in the Tree View panel, right click and select Toggle Active Body
