Vertices turn black with box selection when no constraints are visible
mcv100
Postby mcv100 » Sun May 02, 2021 1:19 pm
I'm seeing a strange issue in the Sketcher, where all vertices (including the origin) turn black after a box selection, unless there are constraint symbols visible. I can reproduce this issue consistently and very easily, even on a fresh 0.19.2 install with all preferences reset. Just make a new file, go into part design, new body, new sketch and draw a rectangle.
The normal behaviour (vertices don't turn black).
Before making (empty) box selection:
After making (empty) box selection:
Now, after deletion of the visible (parallel) constraints.
Adding any constraint with a visible icon again makes the vertices appear normal again. Can anyone reproduce this as well?
OS: Windows 10 Version 1909
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/Netherlands (en_NL)
Re: Vertices turn black with box selection when no constraints are visible
Postby chrisb » Sun May 02, 2021 3:06 pm
Hi and welcome to the forum!
I cannot reproduce, but we have seen this before. There was a discussion about it not long ago. Can you reproduce it when you restart FreeCAD in the same way?
OS: macOS 10.16
Version: 0.20.24720 (Git)
Hash: 8b0c58d1b45017ad42bf0fa8f827f1cf22a398e7
Python version: 3.9.2
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
Locale: C/Default (C)
papyblaise
Postby papyblaise » Sun May 02, 2021 3:19 pm
it did it to me, then more, then redo this day with the new daily version , but isn't catastrofic
mcv100
Postby mcv100 » Sun May 02, 2021 5:46 pm
chrisb wrote: Sun May 02, 2021 3:06 pm Hi and welcome to the forum!
Thanks for the welcome :)
Yes, I can reproduce this at a fresh FreeCAD start, even after a PC restart. I also tried 0.19.1, but I had the same problem. I don't remember seeing this in 0.18 before.
It's indeed not catastrophic, just a bit annoying for the first parts of a sketch when you don't have constraints yet and you are trying to select vertices for a coincidence constraint for example. I mostly use box selection because it's much quicker than trying to aim for a small point directly.
By the way, the quickest way to observe this issue for me is just to start a new sketch, immediately try to do a box select and observe if the origin point turns black.
papyblaise
Postby papyblaise » Sun May 02, 2021 7:04 pm
Exactly the same and for me, even the outline of the box is black and not white
mcv100
Postby mcv100 » Sun May 02, 2021 7:18 pm
And does the black also disappear whenever you draw something else? Perhaps with constraints, like a rectangle.
Postby chrisb » Sun May 02, 2021 8:32 pm
Please create a ticket in the tracker and cross link it with this discussion.
mcv100
Postby mcv100 » Tue May 04, 2021 8:20 pm
Just did, thanks! :)
Postby chrisb » Tue May 04, 2021 9:00 pm
cadilhac
Postby cadilhac » Wed May 05, 2021 9:38 pm
I can reproduce that and then some. After a box select, all the edges and vertices turn black:
When hovering, the colors are restored … partially (note the horizontal/vertical markers):
