Make a GIF
mario52
Re: Make a GIF
Post by mario52 »
Hi koluna
I am sorry but i don't know in home all work well Windows and Kubuntu (USB key)
Are you sure you are looking in the right directory ?
if not i can remove all error tests to testing, tell my if you have not result
i make this little video
mario
koluna
Re: Make a GIF
Post by koluna »
Hi!
I look it for in the directory in the dialog.
There are not any files... I tried to use different directories.
I do not have Windows.
If you make some changes for me, I will test it :)
Thanks for your video.
mario52
Re: Make a GIF
Post by mario52 »
hi
tray this (uncompress and paste in your macro directory)
test also "Save image" button for see if one image is saved
see if on error is displayed in report view and past it here
mario
Screen_Wiki_Testing.zip
(18.67 KiB) Downloaded 32 times
koluna
Re: Make a GIF
Post by koluna »
I tested it.
There are not any errors in a Report view...
mario52
Re: Make a GIF
Post by mario52 »
Hi
i discover the problem is here:
 SaveName, Filter = PySide2.QtWidgets.QFileDialog.getSaveFileName(None, "Export a file",  pathFile, "Image PNG Portable Network Graphics  (*.png);;"
OS: Linux Mint ignore the extension ex: "name" instead "name.png" then create on error in the macro
use the macro and write also the extension with the name ex: "myAnimationName.png"
tell me
(i work for correct this ...)
OS: Linux Mint 20.1 (X-Cinnamon/cinnamon)
Version: 0.20.24847 (Git) AppImage
Hash: 20e756306d9aa624fcbf465f0345d721673ce720
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: C/Default (C)
and i remark Linux Mint not respect the local pays also
mario
koluna
Re: Make a GIF
Post by koluna »
You are right, Mario!!! :)
Thanks a lot!
I added a file extension 'png' and macros worked out :)
I used "New image" and "Save the animation".
koluna
Re: Make a GIF
Post by koluna »
mario52 wrote: Mon May 17, 2021 11:33 am and i remark Linux Mint not respect the local pays also
Hm... what did you mean? I did not understand you.
koluna
Re: Make a GIF
Post by koluna »
My object to animate is selected.
That changes it color.
How can I animate without changing a color?
mario52
Re: Make a GIF
Post by mario52 »
hi
koluna wrote: Tue May 18, 2021 8:18 pm You are right, Mario!!! :)
Thanks a lot!
good news, i work in the new version "Compatible Mint" wait a bit
koluna wrote: Thu May 20, 2021 6:36 am That changes it color.
the unique solution with the object selected, select one vertex less visible and not one face or edge
and if the point is not desired you must edit the image concerned with Gimp or other and colored the point , no more solution
koluna wrote: Tue May 18, 2021 8:20 pm Hm... what did you mean? I did not understand you.
no problem in general this is the local model "Locale: English/UnitedStates (en_US)"
mario
koluna
Re: Make a GIF
Post by koluna »
mario52 wrote: Thu May 20, 2021 8:47 am good news, i work in the new version "Compatible Mint" wait a bit
Thanks. I am waiting for it :)
I guessed it... but it is a wrong way ;(
What do you think about a list of project's objects? We should select an item and macros will work with it.
