cant select new body
Sicario_89
Postby Sicario_89 » Wed May 05, 2021 12:37 am
Grettings!
So, I started editing a sketch to use it in another body with a boolean operation, but I cant select it, nor see it. why is this happening?
CLIP_PROPIO_experimento.FCStd
(35.96 KiB) Downloaded 13 times
David ONeil
Re: cant select new body
Postby David ONeil » Wed May 05, 2021 1:39 am
Try eliminating the interior features circled. Or change the line to a 'construction line'.
Postby chrisb » Wed May 05, 2021 5:41 am
You can't see it, because the body is hidden, and with it everything inside.
Postby chrisb » Wed May 05, 2021 5:55 am
You could also work on your sketching, e.g. by preferring geometric constraints over dimensions: in exterior_frente you have 25 dimensions, of which I could easily remove more than a third, file attached.
CLIP_PROPIO_experimento_cb.FCStd
(28.08 KiB) Downloaded 10 times
Sicario_89
Postby Sicario_89 » Wed May 05, 2021 7:11 am
chrisb wrote: Wed May 05, 2021 5:41 am You can't see it, because the body is hidden, and with it everything inside.
Thank you!, it was exactly that. I didnt knew how to hide/show geometry.
chrisb wrote: Wed May 05, 2021 5:55 am You could also work on your sketching, e.g. by preferring geometric constraints over dimensions: in exterior_frente you have 25 dimensions, of which I could easily remove more than a third, file attached.
Thanks! I will start doing that. Im coming from 3Dmax and neverused a CAD software before. Need to start using spread sheets also, to have everything parametric
Sicario_89
Postby Sicario_89 » Wed May 05, 2021 7:26 am
So, I made a new sketch (for the interior of the piece) and wanted to copy the geometry of the exterior and make a few changes to use it as the interior, but I cant seem to make the exterior sketch visible ( to use the copy geometry tool), what am I missing?
(88.71 KiB) Downloaded 8 times
Postby chrisb » Wed May 05, 2021 7:52 am
You don't necessarily need a spreadsheet to be parametric. To access a sketch from another body, use a PartDesign ShapeBinder.
drmacro
Postby drmacro » Wed May 05, 2021 10:56 am
Sicario_89 wrote: Wed May 05, 2021 7:26 am So, I made a new sketch (for the interior of the piece) and wanted to copy the geometry of the exterior and make a few changes to use it as the interior, but I cant seem to make the exterior sketch visible ( to use the copy geometry tool), what am I missing?
I question the use of the Boolean I the feature tree... :?:
My beginners, written treatise: Learning FreeCAD
Sicario_89
Postby Sicario_89 » Thu May 06, 2021 2:57 pm
Is that not the best way to make that pice? I watched a few youtube videos and they did something similar (altrou I forgot to check the version, they were from a few years). I changed a few things and now its a little better (still a mess with the constraints, but I dont plan to do much changes from now and just print it before saturday).
What do the simbols in the different elements of the tree mean? Some sketches hasve that lilac circle and some dont.
Bance
Postby Bance » Thu May 06, 2021 3:11 pm
