Reusing sketches (again)
RandomPipeBender
Postby RandomPipeBender » Wed May 05, 2021 12:57 am
Hi everyone,
I'd like to construct something out of steel tubing. I made a sketch and would now like to pad it to various length using the part design workbench (similar to this user: https://forum.freecadweb.org/viewtopic.php?f=3&t=58333)
I scrolled through that post and was able to do it as suggested with a shape binder, a sub-object shape binder and the cloning tool from the draft workbench. I don't really understand the implications of using a shape binder over a sub-object shape binder and using the cloning tool from a different workbench also seems dubious.
I found a third way, simply padding the sketch when a new empty body is activated:
phpBB [video]
However the message
PartDesign::Pad / Pad001: Links go out of the allowed scope
in the report view makes me question if this is a sane way of doing it.
So my questions are:
- What's the canonical way of doing this?
- What's the difference between using a shape binder and a sub-object shape binder
- Is the method shown in the video sane? a bad idea?
Thanks in advance!
Re: Reusing sketches (again)
Postby chrisb » Wed May 05, 2021 5:39 am
Hi and welcome to the forum!
RandomPipeBender wrote: Wed May 05, 2021 12:57 am - What's the canonical way of doing this?
Using a ShapeBinder
In this case it's the same. In general the SubShapeBinder has its own (non hidden) placement and can bind more than one object.
Sane: no; bad idea: yes. You must not directly reference things crossing the body border without a (Sub)ShapeBinder.
RandomPipeBender
Postby RandomPipeBender » Wed May 05, 2021 5:40 pm
Thanks. That was most helpful!
