Boolean cut with object from Fasteners in Part Design
FredOP
Postby FredOP » Wed May 05, 2021 12:38 pm
Can you show me how to cut the thread in the connector body ?
I assume it's made using Boolean Cut but I can't find the right setup.
cut.thread.FCStd
(61.32 KiB) Downloaded 8 times
drmacro
Re: Boolean cut with object from Fasteners in Part Design
Postby drmacro » Wed May 05, 2021 1:06 pm
Done in Part Design and in Part workbenches:
Snip macro screenshot-d2ae14.png (150.51 KiB) Viewed 281 times
cut.thread_inPD.FCStd
(227.34 KiB) Downloaded 12 times
cut.thread_inP.FCStd
(100 KiB) Downloaded 4 times
My beginners, written treatise: Learning FreeCAD
bambuko
Postby bambuko » Wed May 05, 2021 1:21 pm
drmacro wrote: Wed May 05, 2021 1:06 pm Done in Part Design...
In PD, why do you have two taps, please?
FredOP
Postby FredOP » Wed May 05, 2021 1:56 pm
drmacro wrote: Wed May 05, 2021 1:06 pm Done in Part Design and in Part workbenches:
Thanks
So.. I managed to do it by preselecting the "ScrewTap" itself ( not the body), then doing Boolean / Cut.
I don't know why it is working, because the feature is clearly asking for "two or more BODIES", however .. it is working.
Also, I don't think your solution in PD with 2 screwTaps AND the body is correct, as I can barely open it on my dual 32 cores Xeon (not sure which operations are multithreaded in FreeCAD / libocc though)
This is a bit confusing because the screwTap was stolen by the Boolean and the thread Body is now empty.
Maybe it was not in the thread body to begin with ?
bambuko
Postby bambuko » Wed May 05, 2021 2:09 pm
FredOP wrote: Wed May 05, 2021 1:56 pm ...I don't know why it is working, because the feature is clearly asking for "two or more BODIES", however .. it is working...
I can confirm that what you did works easily in Part Design
step 1 - toggle "connector" into active body
step 2 - preselect screw tap
step 3 - click boolean
and hey presto
BTW two bodies are:
1 - active "connector"
2 - preselected screw tap
It is a bit confusing (I mean boolean ;) )
Also - one is supposed to be able to select second body after activating boolean command,
but for some reason with the tap only preselection works... :oops: :roll:
drmacro
Postby drmacro » Wed May 05, 2021 2:44 pm
bambuko wrote: Wed May 05, 2021 2:09 pm ...
But, by doing this you have have mixed Part Design and Part workbench. Not recommended if you don't understand what you've done.
That it works doesn't make it good practice.
That is why in the PD only solution I provided, the tap is d-n-d into the thread body first. Then the Boolean is done between 2 Body objects.
As to your question of why two taps...I have no idea, it does that automagically...
bambuko
Postby bambuko » Wed May 05, 2021 3:13 pm
drmacro wrote: Wed May 05, 2021 2:44 pm ... the tap is d-n-d into the thread body first...
what is d-n-d please?
Postby chrisb » Wed May 05, 2021 3:25 pm
bambuko wrote: Wed May 05, 2021 3:13 pm what is d-n-d please?
Drag-and-drop?
Concerning mixing Part and PartDesign, I think it is easier to understand that applying a Part Cut (or other boolean) to the whole body is allowed, than to understand the PartDesign booleans.
bambuko
Postby bambuko » Wed May 05, 2021 3:34 pm
chrisb wrote: Wed May 05, 2021 3:25 pm ...Drag-and-drop?...
thank you :P
chrisb wrote:...it is easier to understand that applying a Part Cut (or other boolean) to the whole body is allowed, than to understand the PartDesign booleans.
as always I am confused :mrgreen:
I haven't gone anywhere near Part workbench and I used Part Design boolean,
so I didn't use Part Cut (I thought I used Part Design boolean...)
so are we saying that thread tap is part not a body, hence recommendation to avoid mixing the two?
BTW, when following PD d-n-d route, it works fine, but sometimes with following warning:
16:35:32 0 Tree.cpp(302): [TreeView] duplicate child item cut_thread_inPD#Boolean.ScrewTap
16:35:43 10.9076 Tree.cpp(302): [TreeView] duplicate child item cut_thread_inPD#Boolean.ScrewTap
16:36:51 78.8212 Tree.cpp(302): [TreeView] duplicate child item cut_thread_inPD#Boolean.ScrewTap
and (maybe because I am using 0.20)
I had no double vision :lol:
OS: Windows 10 Version 1909
Version: 0.20.24787 (Git)
Hash: ea96f1860164ff8a6751b21b3fb4d425fc87f5e5
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
