What is the description column for in the tree?
run_the_race
Postby run_the_race » Wed May 05, 2021 5:19 pm
I checked the wiki and it does not mention it: https://wiki.freecadweb.org/Tree_view
In the tree view what is the `Description` column for? I would have guessed there would be a description property one could set, and then it shows in the tree, but turns out not.
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
bambuko
Re: What is the description column for in the tree?
Postby bambuko » Wed May 05, 2021 5:31 pm
label 2
run_the_race
Postby run_the_race » Wed May 05, 2021 8:00 pm
bambuko wrote: Wed May 05, 2021 5:31 pmlabel 2
Thanks for that insight. I went through a few of my files and could not find something that has a `label2` property, what uses labels2?
bambuko
Postby bambuko » Wed May 05, 2021 8:43 pm
you have:
internal (system generated) name
label
label 2
label replaces name in tree view
label 2 is displayed as description in tree view
if you select an item in tree view, all these will be displayed in properties window
all above from memory (haven't got FreeCAD PC available at the moment)
5 seconds with interweb search, results in :mrgreen:
https://wiki.freecadweb.org/Object_name
Postby chrisb » Wed May 05, 2021 9:50 pm
run_the_race wrote: Wed May 05, 2021 5:19 pm I would have guessed there would be a description property one could set, and then it shows in the tree, but turns out not.
Yes it is:
run_the_race
Postby run_the_race » Thu May 06, 2021 8:03 am
chrisb wrote: Wed May 05, 2021 9:50 pm
Yes it is:
Did you add that property via python? I went through the `Data` and `View` properties and could not see a `label2`.
Bance
Postby Bance » Thu May 06, 2021 8:07 am
Did you read the wiki page bambuko linked?
bambuko
Postby bambuko » Thu May 06, 2021 8:10 am
run_the_race wrote: Thu May 06, 2021 8:03 am ...Did you add that property via python? ...
No, like I have said before - "property view"
(or double click on the description space in tree view and type directly there)
property view.jpg (32.8 KiB) Viewed 199 times
Postby chrisb » Thu May 06, 2021 8:18 am
Clicking on the right side in tree view is also possible :roll: .
Roy_043
Postby Roy_043 » Thu May 06, 2021 9:57 am
For Label2 to be displayed in the properties you must right click and check "Show all". See Property_editor.
