Trouble positioning bodies for Boolean in PartDesign
Obliterax
Postby Obliterax » Thu May 06, 2021 12:55 am
Hi everyone,
I'm trying to figure out how to position one PartDesign part with respect to another so that I can perform a boolean cut. I am trying to make a threaded hole in a part to be 3D printed, but the boolean tool keeps putting the hole somewhere other than where the cutout body is located.
If I'm reading the wiki right, the body that material is being removed from needs to be positioned at the world origin, but not the part that's being removed. That's the way I have it set up now. I also tried it with the cutout part at the origin and the main body elsewhere, but had similar problems.
Tricky Bore.png (22.8 KiB) Viewed 317 times
If there's an easier way of handling this, I'm open to that, but I'm not using the built-in hole tool because I need to print the screw, too. The file I attached is pre-boolean.
Thanks One Million!
Mount m2.FCStd
(616.14 KiB) Downloaded 5 times
Re: Trouble positioning bodies for Boolean in PartDesign
Postby chrisb » Thu May 06, 2021 5:41 am
Your model doesn't include the boolean cut, so I am guessing: You applied the boolean to the features. This is not allowed, you must apply Part booleans to the bodies. However, it still doesn't work, probably due to some coplanar feature. I have to investigate this further. Can take a while. In the meantime, try turning or lifting the thread ba a minimal amount.
Postby chrisb » Thu May 06, 2021 7:00 am
A recompute shows errors in Sketch001, it has redundant constraints. Furthermore the external line seems to be unneeded, you can use the center for reference instead.
You shouldn't have detached the ShapeBinders from their source, you loose parametricity of the threads.
Bore 1 shows errors with CheckGeometry.
You should fully constrain your sketches. Especially for Core it is important to have some overlap with the thread. This fixes the geometry check. And then the boolean works.
I have not yet performed the cut itself in order to reduce the size of the model.
Mount_cb.FCStd
(845.46 KiB) Downloaded 8 times
Obliterax
Postby Obliterax » Fri May 07, 2021 5:43 am
I got it to work the way I wanted it to. It looks like the problem was that the rotations of the body and the bore weren't the same. Once I set the angle to zero and the axis to [0,0,1] for both of them, they ended up where they were supposed to be.
You were totally right about making the core bigger, though. I guess that must be a problem with trying to fit a B-spline to a circle?
Regarding your suggestions: Is there a way to get the original helix into the Bore body? Or can you make a helix in PartDesign mode? I'd have preferred to do that, but I couldn't figure out how. And does the geometry checker work on PartDesign parts, too?
Thanks for your insights!
Postby chrisb » Fri May 07, 2021 6:11 am
Obliterax wrote: Fri May 07, 2021 5:43 am I got it to work the way I wanted it to. It looks like the problem was that the rotations of the body and the bore weren't the same. Once I set the angle to zero and the axis to [0,0,1] for both of them, they ended up where they were supposed to be.
Even then not use a Part boolean on a feature, but only on whole bodies.
Sort of, but it occurs with simpler shapes too. It is - my guess - the limited precision when calculating planes that just touch. It can happen, that they don't really touch, but that they cross more than once. Something that is not possible in pure geometry.
Yes and yes. You can edit the bodies Group property and add the helix, and you can use the helix feature in the current FreeCAD version. Which shows, how important it is to add the FreeCAD infos to topics.
Yes, on any shape. And probably easyer - and more convincing - would have been to try it; it's only four clicks away.
drmacro
Postby drmacro » Fri May 07, 2021 9:38 am
With Geomtry check, it is more thorough with the BOP option ticked.
My beginners, written treatise: Learning FreeCAD
