Is it possible to change the object SubShapeBinder is bound to?
run_the_race
Post by run_the_race »
I started my project with one file per part. I am busy trying to combine all the parts into one file. A left over of this is that SubShapeBinder objects would refer to a linked version of the part. Now the part is directly in the file, so I wish to change the subshapebinder to point directly to the part in the same file.
If I double click on the subshapebinder object nothing happens, and the "Support" property is not editable. Is it possible to change the object SubShapeBinder is bound to?
I could create new shape binder objects, label them the same, move them into the same position, but I suspect under the hood FreCAD uses the name not label, so I suspect everything will get broken.
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Chris_G
Re: Is it possible to change the object SubShapeBinder is bound to?
Post by Chris_G »
The "Support" property of a sub-shape binder is read-only.
You can enable write access to the property by selecting the binder in the TreeView and typing this in the python console :
Gui.Selection.getSelection()[0].setEditorMode("Support", 0)
WARNING : The "Support" property is probably write-protected for a good reason, and I have no idea of the consequences of bypassing it.
So, do it at your own risks, and make backup copies ...
Bance
Post by Bance »
Did you try merge projects?
Std_MergeProjects
run_the_race
Bance wrote: Fri May 07, 2021 4:05 pm Did you try merge projects?
Std_MergeProjects
That sounds like the tool made for the job. Unfortunately I saw this too late. Have already spent quite a few days on the manually combined version :cry: But thank you, I know for next time and hopefully it helps fellow FreeCAD googlers! :)
run_the_race
Chris_G wrote: Fri May 07, 2021 12:29 pm The "Support" property of a sub-shape binder is read-only.
Thahnks for that, ok sounds like something not to be changed, warning heeded, will stay away from that. :!:
