Is it possible to reload imported step file
run_the_race
Post by run_the_race »
I am working on a design, which is proving very difficult to squash in. Hence I make an attempt at the layout in KiCAD, and then import the step file into FreeCAD to check if it fits, then change something and try again.
I do this process over and over:
  1. Export step file from KiCAD to overwrite old step file.
  2. Delete old Part from FreeCAD.
  3. Import new step file.
  4. Transform the new part into the same position as before.
I was wondering if it is possible in FreeCAD, instead of deleting the part of the imported step file, is it possible to reload/relink it? Save positioning again every time I change something.
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Re: Is it possible to reload imported step file
Why don't you keep the imported object?
easyw-fc
Post by easyw-fc »
run_the_race wrote: Wed May 12, 2021 8:27 am I am working on a design, which is proving very difficult to squash in. Hence I make an attempt at the layout in KiCAD, and then import the step file into FreeCAD to check if it fits, then change something and try again.
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
you may have a look at kicadStepUp WB
Kicad StepUp: a Seamless ECAD/MCAD PCB Data Integration @kicad.info forum
https://youtu.be/6R6UEUScjgA
run_the_race
Wow that looks like more than what I ever could have asked for, brillant stuff, thank you! :D
