[SOLVED] Understanding Rotation & Placement
gbroques
Post by gbroques »
I need help understanding how rotations and placement works.
Let me provide a simple example and form a question to illustrate what I don't understand.
Consider the following "tower" shape, a cone placed on top of a cylinder in a Std Part (see below screenshot).
The cylinder has a height of 10.
Now, I want to rotate about (0, 0, 10), the center of where the cone meets the cylinder, around the X axis, 5 degrees.
See the following code snippet.
Draft.rotate([FreeCAD.ActiveDocument.Part], 5.0, FreeCAD.Vector(0.0, 0.0, 10.0), axis=FreeCAD.Vector(1.0, 0.0, 0.0), copy=False)
After performing this rotation, the Y becomes 0.87 mm, and Z becomes 38.05 um (both were previously 0).
These are what I'd like to know how to calculate, or the formula FreeCAD uses to come up with these numbers.
How would I calculate the placement offset after the rotation is performed?
Please help me understand how this works. :)
00001000bit
Re: Understanding Rotation & Placement
Post by 00001000bit »
You pivoted on the top, so the bottom (where the origin was) moved accordingly. The new offset is simply a result of the rotation being fixed at the end opposite of the origin, instead of rotating around the origin itself.
You know the height of the cylinder (c) and the angle (5 deg or 85 deg, depending on which one you choose), so you can figure out the other dimensions using some simple trig.
The height offset is defined by the side of the triangle "a" which can be figured as sin(85)=a/10
which figures out to: 9.96194698091746 - when subtracted from the original 10, gives you 0.038053019082545
The width offset is defined by the side of the triangle "b" which can be figured as cos(85)=b/10
which figures out to: 0.871557427476581
Note: in python, you'll need to convert degrees to radians to use in the sin/cos functions "math.radians(85)"
gbroques
Post by gbroques »
00001000bit wrote: Wed May 12, 2021 4:33 pm You pivoted on the top, so the bottom (where the origin was) moved accordingly. The new offset is simply a result of the rotation being fixed at the end opposite of the origin, instead of rotating around the origin itself.
Thank you very much for this explanation. It helps immensely!! :D
edwilliams16
Re: [SOLVED] Understanding Rotation & Placement
Post by edwilliams16 »
To make the figure less crowded, I've rotated it by 30 degrees instead of 5 degrees. Call the angle theta. We've rotated our object about the x-axis through C (=Vector(0,0,10)). The original origin of the body moves from O to the point Z along a circular arc. Its new coordinates are (0, OY, YZ)
It is now basic trigonometry:
OY = CZ * sin(theta) = 10 *sin(5 deg) = 0.87155742747 mm
YZ = OC - CZ*cos(theta) = 10 - 10*cos(5 deg) = 0.03805301908 mm
Maybe that is sufficient, but this case was greatly simplified because it only need two dimensions to draw it. The more general case is what is the new location P' of a point P if the body is rotated by theta degrees about an axis parallel to n through a offset center C? Naturally, FreeCAD provides the tools for this.
P = Vector(Px,Py,Pz)
C = Vector(Cx, Cy, Cz)
n = Vector(nx,ny,nz)
rot = Rotation(n, theta)
Pprime = C + rot.multVec(P - C)
In the case of P being the origin (zero vector), this simplifies to:
Oprime = C - rot.multVec(C)
gbroques
Post by gbroques »
edwilliams16 wrote: Wed May 12, 2021 5:04 pm offset_rot.png
Thank you! Exceptional answer as well.
This helps a lot! :)
edwilliams16
I've added a section on offset rotations to my Sandbox wiki page. https://wiki.freecadweb.org/Sandbox:Edw ... _rotations
gbroques
Post by gbroques »
edwilliams16 wrote: Wed May 12, 2021 5:37 pm I've added a section on offset rotations to my Sandbox wiki page. https://wiki.freecadweb.org/Sandbox:Edw ... _rotations
Thank you.
This looks like a great resource!
