Can't pad a sketch based on external geometry
NewJoker
Postby NewJoker » Wed May 12, 2021 4:55 pm
I am testing the "External Geometry" tool. I started from creating this simple part and offsetting a plane from its face:
Then I created a sketch on this plane and used the "External Geometry" tool to project the edges of the previously created part on the new sketch:
Finally, I outlined the projected contour with line tool. Now the problem is that I can't use Pad tool on this new sketch:
sketch 2.JPG (33.86 KiB) Viewed 370 times
What's going on here ? Am I doing something wrong ?
Thanks in advance for your help.
drmacro
Re: Can't pad a sketch based on external geometry
Postby drmacro » Wed May 12, 2021 5:09 pm
See if this example helps.
The Datum plane is not needed. Also, it is recommended to avoid attaching sketches to generated geometry because of the topological naming problem.
https://wiki.freecadweb.org/Topological_naming_problem
https://wiki.freecadweb.org/Feature_edi ... ble_models
https://wiki.freecadweb.org/Basic_Attachment_Tutorial
Snip macro screenshot-4a458d.png (178.89 KiB) Viewed 360 times
PadExample.FCStd
(25.15 KiB) Downloaded 4 times
My beginners, written treatise: Learning FreeCAD
NewJoker
Postby NewJoker » Wed May 12, 2021 5:15 pm
Thank you very much. However, I actually planned to extrude it in the opposite direction (so that a new solid, separated from the original one by a gap, will be created) and that's why I use plane with offset. Is it possible to do it the way I wanted ?
I also tried deleting those lines created with External Geometry tool to avoid dependencies but it didn't help.
Bance
Postby Bance » Wed May 12, 2021 5:36 pm
NewJoker wrote: Wed May 12, 2021 5:15 pm Is it possible to do it the way I wanted ?
No, there is a single solid rule for bodies.
You must instead use a shape binder in a new body.(there are other methods including carbon copy!) :D
NewJoker
Postby NewJoker » Wed May 12, 2021 5:47 pm
Bance wrote: Wed May 12, 2021 5:36 pm
That's what I also tried - creating a new body and moving the second sketch to it. But I couldn't do it this way. ShapeBinder might be a good option but for it to work the target body must already exist, right ?
Bance
Postby Bance » Wed May 12, 2021 6:02 pm
Yes, Carbon copy might be good here.
Create a new body and sketch, select CC tool, press CTRL ALT and select original sketch. ( better if pad is invisible at this time)
NewJoker
Postby NewJoker » Wed May 12, 2021 6:26 pm
Thanks, CarbonCopy tool works fine in this case:
But I still wonder if it's possible to achieve the same effect using External Geometry tool.
Bance
Postby Bance » Wed May 12, 2021 6:44 pm
No not between bodies, you need to import geometry with a shape-binder then use ext geom.
Anyway it is much better not to reference solid (generated) geometry at all.
See Topological naming problem.
NewJoker
Postby NewJoker » Wed May 12, 2021 7:03 pm
Great, this works as well:
part 2.JPG (50.04 KiB) Viewed 282 times
In this case it's also necessary to hide the original pad.
Again, thank you guys for help.
Postby chrisb » Wed May 12, 2021 8:18 pm
If both parts are equal you should consider to use a clone, or if you can arrange them appropriately, a mirror.
