Broken Base Pad
alfredopalhares
Broken Base Pad
Post by alfredopalhares »
I for sure cannot find a reason why my base sketch is not recomputing from the updated values on the spreadsheet.
When Updating the pad I get this:
I have just ran out of ideas
Bash Guard.FCStd
(54.08 KiB) Downloaded 49 times
Bance
Re: Broken Base Pad
Post by Bance »
You have bad geometry in the base sketch, looking at it, it's too complicated, I can't be bothered to go further.
You can use the validate sketch tool to analyse and fix it.
alfredopalhares
Re: Broken Base Pad
Bance wrote: Wed May 12, 2021 11:57 pm You can use the validate sketch tool to analyse and fix it.
I have tried the validade sketch tool.
No problems found
Roy_043
Re: Broken Base Pad
Post by Roy_043 »
I get a degenerated geometry warning. There is a circle with R=0 ('4-Circle').
Bance
Re: Broken Base Pad
Post by Bance »
That aside, your model is prone to breaking if you use solid geometry as reference, rather use the underlying sketch.
