Create Face object using Edges intersections
Re: Create Face object using Edges intersections
Postby chrisb » Sun May 16, 2021 9:25 pm
I still don't see a Sketcher problem, but I see that the documentation of Part Slicle says that the objects must not have self intersections, which your sketches and the slicing planes definitely have.
jtm2020hyo
Postby jtm2020hyo » Fri May 28, 2021 8:37 pm
mario52 wrote: Fri May 14, 2021 11:22 am hi
try this macro (ordinate the selections):
with snippet picked in forum Making a Face from makeWire()
Configuration:
_________________________________________________
# if createWire = 0 create face
# if createWire = 1 create Line
# if createWire = 2 create point in intersection
# if createWire = 3 or other create face Line point
hello again, What part should be edited in your script to use it in Sketcher WB to apply _Split and _Coincident at the intersections of multiple _Edges using your script?
before:
after:
OS: Windows 10 (10.0)
Version: 0.20.24847 (Git)
Hash: 20e756306d9aa624fcbf465f0345d721673ce720
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: Spanish/Peru (es_PE)
jtm2020hyo
Postby jtm2020hyo » Mon May 31, 2021 1:21 am
thanks to everyone for the help.
I tested everything that I found on the internet and all method basically are Extrude between Round Helix and a Solid, I mean this fail when the base object is not regular, included Macro_Spring_On_Surface.
So with this, I can confirm we have not a Helix tool but I think we could recyclate other tools.
What do we need to edit each Helix element (100 wires rotate around a circle and elevate en each segment) to rotate each element parallel to any Sketcher Boundary Closed? or similar?
if this task is solved, I think we could create more easy Slab Stairs Objects.
test2-helix.FCStd
(9.52 KiB) Downloaded 26 times
mario52
Postby mario52 » Mon May 31, 2021 9:46 am
hi
jtm2020hyo wrote: Fri May 28, 2021 8:37 pm intersections of multiple _Edges using your script?
you have Sketcher_Split Image
jtm2020hyo wrote: Mon May 31, 2021 1:21 am I tested everything that I found on the internet and all method basically are Extrude between Round Helix and a Solid, I mean this fail when the base object is not regular, included Macro_Spring_On_Surface.
the macro work as needed maybe you use the not good tools or not good method for your project
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
