Is there a method to move windows and doors in the wall?
friv
Post by friv »
Hi All!
Dear friends, please tell me how to move a previously created window or door in the wall to Arch Workbench? Maybe there is a way to move previously created windows or doors through their own sketches? I need to find a way to adjust the position of the window or door to the desired position of the wall.
Best regards, Friv.
Willem
Re: Is there a method to move windows and doors in the wall?
Post by Willem »
Select the window or door in the treeview, it is under the wall. You can manually change the position.
Here is a tutorial https://wiki.freecadweb.org/Tutorial_cu ... _and_doors
friv
Post by friv »
Willem wrote: Fri May 14, 2021 7:17 am Select the window or door in the treeview, it is under the wall. You can manually change the position.
I know a way to move by changing the coordinates. But I need a way to move the created object along the wall either with the mouse or by changing constraints in sketches.
I have read WIKI.
thomas-neemann
Post by thomas-neemann »
friv wrote: Fri May 14, 2021 6:22 am
is that helpful?
https://www.youtube.com/watch?v=_ugxecR_yjs
phpBB [video]
friv
Post by friv »
thomas-neemann wrote: Fri May 14, 2021 8:41 am
is that helpful?
Veri helpful. Thank you!
I watched the video at a speed of 0.25 to see the desired button ;)
