Bodies absorbing other bodies from different parts.
Scott_
Postby Scott_ » Fri May 14, 2021 9:17 am
Hello everyone,
I'm experiencing an issue where bodies within parts are including bodies from other parts into themselves. I'm designing a guitar amp cab, which is pretty much just a box. I created the fron panel first, then added the bottom, then top, then one side. I created each as a new part and a new body in said part. Part Design Workbench, Create a new body and make it active, Create a new sketch, then close the sketch, select the face on an existing part upon which I wish to sketch, Set the 'support' of a sketch, do the sketch, Pad a selected sketch. Now, as I toggle the visibility of each part (or the single body within) it includes duplicates of the other parts that came before it.
This is the first part and the second part showing the overlap:
Screen Shot 2021-05-14 at 18.45.35.png (45.76 KiB) Viewed 302 times
It would guess that it's something to do with my 'Set the 'support' of a sketch approach. I used Inventor at school and am used to being able to click on a face of one part and sketch a different part so that's what I'm trying to do. Is there a better way to do this in FreeCAD? I did have to search around to find the approach I have been using, but I couldn't see an easier way of doing it. I'm also very open to advice about other better ways to approach this.
Thanks in advance,
Scott
OS: macOS 10.15
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
Re: Bodies absorbing other bodies from different parts.
Postby chrisb » Fri May 14, 2021 9:50 am
Hi and welcome to the forum!
Without the file this is mere guesswork: You may have used references across body borders, which is not allowed. You should see "Links go out of allowed scope" warnings in report view, and the Dependency Graph shows the forbidden references in red.
If you want to reference things from other bodies: use a PartDesign ShapeBinder.
If there is only one body in the Part container: omit the container, it serves no purpose.
Scott_
Postby Scott_ » Sat May 15, 2021 2:58 pm
chrisb wrote: Fri May 14, 2021 9:50 am Hi and welcome to the forum!
Hi chrisb,
Thanks for your prompt reply. I have remade the model following your advice and am exploring how best to use the Shapebinder tool. I'm also looking into datum planes as they seem to have a similar function for this application but also allow the plane to be offset from the surface from which it is derived.
-Scott
Postby chrisb » Sat May 15, 2021 9:44 pm
Scott_ wrote: Sat May 15, 2021 2:58 pm I'm also looking into datum planes as they seem to have a similar function for this application but also allow the plane to be offset from the surface from which it is derived.
You can attach sketches in the same way like DatumPlanes, including the offset. DatumPlanes are helpful, if you have more than one sketch to place on them.
