Artifact at start and end interface of subtractive sweep
kishore
Postby kishore » Sat May 15, 2021 10:17 am
I was creating a worm gear and I'm getting an artifact that I think is the result of some rounding errors. My question is how do I fix it or work around it? I considered sweeping over the same edge (circle) twice to overpass the artifact but I cannot select the same circle to sweep again. I know i can create a second circle sketch and use that as the second edge in the sweep
I am unable to attach the file due to file size of 2.1MB.
OS: KDE neon User Edition 5.21 (KDE/plasma)
Version: 0.19.24276 (Git) AppImage
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: English/India (en_IN)
Re: Artifact at start and end interface of subtractive sweep
Postby chrisb » Sat May 15, 2021 10:34 am
If you followed all the tipps in the Thread for Screw Tutorial and the issue persists, upload the file to a publicly available file service (without the need to register for others).
Willem
Postby Willem » Sat May 15, 2021 10:45 am
It is difficult to guess, how did you make this, in Partdesign or in Part workbench. Did you use a Part helix or a Partdesign subtractive helix.
A common mistake is that the sketch is on the same angle as the split of the cylinder. Here an example of how it works
subtractiveSweep.FCStd
(526.31 KiB) Downloaded 8 times
Postby chrisb » Sat May 15, 2021 12:03 pm
Thinking about it: it could also be a misaligned sketch. It is best to attach the section with attachment mode FrenetNB without any further rotation.
kishore
Postby kishore » Mon May 17, 2021 7:28 am
I have uploaded the file here.
Willem wrote: Sat May 15, 2021 10:45 am It is difficult to guess, how did you make this, in Partdesign or in Part workbench. Did you use a Part helix or a Partdesign subtractive helix.
It is made in partdesign with subtractive sweep where an internal involute gear is sweeping around a cylinder. The sweep path is a circle that is concentric with the cylinder but since I require the profile to twist along its axis by one tooth angle, a suitable aux path is constructed as a helix.
