I am looking to create a repeating pattern using the "MultiTransform" tool. Here is my goal:
Here is where my drawing is now:
I would like to be able to add a "linear patern" on the XY plane but with an angle of 60 °.
I tried adding an axis (Local_CS), a line (DatumLine). But I can't select this directions in the "MultiTransform" window
Do you have a solution for me?
Edit: adding the images
Custom axis using the "MultiTransform"
Re: Custom axis using the "MultiTransform"
Hi and welcome to the forum!
Did you delete the MultiPattern before adding the LCS? Otherwise you may have a dependency issue. You can upload the file for further inspection.
Hi Chrisb and thanks for your response.
It's ok with a DatumLine if it has been created before the MultiPatern. Even though the LCS is created before the MultiPatern, I can't seem to use it.
Freecad is realy a great application !!
The three arrows are not really lines that you can select. Also: You don't need the LCS for attachign the DatumLine, you attach it directly.
Thx, i will used DatumLine.
- piece.PNG (237.32 KiB) Viewed 343 times
