Possible bug(ette) in Pick Screen Color
Samantha.UK
Post by Samantha.UK »
I've noticed what appears to be some odd behaviour in the Select Color dialog.
When using the Pick Screen Color, the selection pointer is restricted to sampling inside the dialog box.
CleanShot 2021-05-16 at 11.50.05@2x.png (298.63 KiB) Viewed 285 times
This contrasts with the Spreadsheet color picker where the eyedropper tool can sample anywhere on the screen.
CleanShot 2021-05-16 at 11.47.14@2x.png (1022.93 KiB) Viewed 285 times
System Details
OS: macOS 10.15
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
I've searched for threads/bug reports to no avail ... hence this post to check before possibly reporting on the bug tracker ...
Ta muchly, Sam.
Re: Possible bug(ette) in Pick Screen Color
Hi and welcome to the forum!
Confirmed. If nobody else responds, you may create a ticket for this.
There seems to be a workaround: Place the color picking window over the color you want to pick. Then move the mouse pointer at a side or at the bottom out of the window over the desired color. In the moment you leave the color picker it selects the color outside of the window.
This doesn't work when I move the mouse pointer too fast.
OS: macOS 10.16
Version: 0.20.24825 (Git)
Hash: ccc4151b3020969450325466e385850783795325
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Samantha.UK
chrisb wrote: Sun May 16, 2021 12:12 pm Hi and welcome to the forum!
Thanks Chris :)
