Installing Assembly3 Workbench
edwilliams16
Post by edwilliams16 »
I wanted to play with this. In the addon manager, I added it via the configure https://github.com/realthunder/FreeCAD_assembly3
When I start up FreeCAD, I now get the error message
09:57:29  3.979707 <asm3.main> init_gui.py(14): no solver backend found
which very much sounds like it won't work.
Is this broken, or should I ignore this? Can anyone point me at a simple example of some object constrained to rotate around some axis?
OS: macOS High Sierra (10.13)
Version: 0.19.24291 (Git)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
bambuko
Re: Installing Assembly3 Workbench
Post by bambuko »
Yes, it is a problem.
You can copy assembly folder from Link branch and it will be fine.
https://forum.freecadweb.org/viewtopic.php?f=20&t=57462
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
edwilliams16
The bottom line was to replace the
...FreeCAD/Mod/FreeCAD_assembly3/freecad/asm3
folder with the corresponding folder from an install of realthunder's branch?
EDIT
I just recursively diffed the two assembly3 Mod/ directories between my current FreeCAD and the daily FreeCAD-linkstage3 and they are identical. So I didn't try this.
edwilliams16
Couldn't get asm3 to work with the release 0.19.24291.
However it did work with
Version: 0.20.24894 (Git)
Hash: a378b6b66f8a5992fc1452567ff59bdb613abc80
Python version: 3.9.4
Qt version: 5.12.9
OCC version: 7.5.2
Assembly3 needs an additional library which isn't included in master. However, Looo packages it with some (all/conda?) versions.
bambuko
Post by bambuko »
edwilliams16 wrote: Sun May 16, 2021 10:18 pm I just recursively diffed the two assembly3 Mod/ directories between my current FreeCAD and the daily FreeCAD-linkstage3 and they are identical. So I didn't try this.
Sorry for being so brief and imprecise in my answer (time difference meant I was falling asleep while typing reply ;) )
Directories might look the same but their content is not - there is a problem with solver in 0.19
(as chrisb says some things are not included...)
If you had copied rather than recursively diffed it would have worked :mrgreen:
(I know because I have done it in the days when I still used 0.19)
Anyway, you have found the easiest solution - 0.20 has been sorted out and works OK.
As for your second question (examples), you could do worse than have a look at excellent webpage on the subject (including examples) by jpg87:
http://help-freecad-jpg87.fr/02_ass_ind.php
edwilliams16
Actually I did try a copy, just in case it all depended on the top directory name somehow - but it didn't work with my particular build.
The reference link was very useful. I hadn't found useful tutorial stuff on the web.
