How to fix "migrate from legacy"
rrrroonn
Postby rrrroonn » Mon May 17, 2021 12:40 am
I frequently get this error popping up. The document was not created in a prior version. Any suggestions about how to fix this?
What additional info should I provide if it happens again (if any)?
thank you
Ron
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Re: How to fix "migrate from legacy"
Postby chrisb » Mon May 17, 2021 5:36 am
This happens, if a PartDesign feature occurs not inside of a body. I can't see such thing in your model. Can you upload it?
rrrroonn
Postby rrrroonn » Mon May 17, 2021 8:46 am
If I get it again, I will save a copy and upload. Thank you.
rrrroonn
Postby rrrroonn » Mon May 17, 2021 9:47 pm
It happened again.
The file is too large for the forum so I put it on my google drive here:
https://drive.google.com/drive/folders/ ... sp=sharing
I had just deleted some steps out of the model due to design changes, made the "Hotend-rocker001 active, and started to create a new sketch. At that stage I selected "Migrate manually" and saved the file. When I started a sketch again and hit "Yes" to migrate, I get error "Object can only be in a single GeoFeature group". It created a new body called "AdditivePipeBody" with just an origin.
Hopefully this is helpful in diagnosing the problem.
thank you,
Ron
rrrroonn
Postby rrrroonn » Mon May 17, 2021 10:23 pm
It seems that the file is now corrupt, because sketching seems to be broken. When I try to sketch a polyline in Sketch093, a red message "Solving sketch failed, Internal name Sketch093" comes up. Removing all constraints and reapplying seems to allow me to progress.
I have uploaded the file.
https://drive.google.com/file/d/18jSW7g ... sp=sharing
thank you,
Ron
rrrroonn
Postby rrrroonn » Mon May 17, 2021 10:51 pm
No I cannot continue - every sketch I now do has issues. I really hope that you are able to diagnose this as I have put days of work into this model.
thank you in advance,
Ron
Postby chrisb » Mon May 17, 2021 11:06 pm
You have created illegal references from sketches tool_path and tool_circle in Hotend-rocker to Hotend_mount_cutout. That could be the reason for the message.
Postby chrisb » Mon May 17, 2021 11:35 pm
My first guess was better: The additive pipe and the revolution are features without body. The attached file was derived from your file:
Snip macro screenshot-0069ed.png (48.07 KiB) Viewed 559 times
Even without this, your file was a pretty mess where I had difficulties to find my way through all the references going to and fro. A clear concept may help you to keep the overview.
migrate.FCStd
(15.92 KiB) Downloaded 7 times
rrrroonn
Postby rrrroonn » Tue May 18, 2021 1:46 am
chrisb wrote: Mon May 17, 2021 11:06 pm You have created illegal references from sketches tool_path and tool_circle in Hotend-rocker to Hotend_mount_cutout. That could be the reason for the message.
Hi Chris,
Forgive my ignorance, I am not a long time CAD user and have only begun to use FreeCAD ...
How do I create illegal references? I want to avoid doing it again, obviously.
thanks
Ron
rrrroonn
Postby rrrroonn » Tue May 18, 2021 2:11 am
chrisb wrote: Mon May 17, 2021 11:35 pm My first guess was better: The additive pipe and the revolution are features without body. The attached file was derived from your file:
Its probably messy because I am far from proficient with how things work in FreeCad. I guess I originally thought that something like a revolution or a pipe created a body but that was just my ignorance. I sort of assumed that the program wouldn't let me do something "illegal" or "wrong".
Sorry, but how do I fix this without starting from scratch? Using the file you provided, I have tried various ways to add these things to a body, but have not been successful. Your advice is REALLY appreciated.
thank you,
Ron
