Hi evrybodies
does anyone have anything to show this tilted face in light blue in full size, in other words in front view in Techdraw page
OS: Windows 10 Version 2009
Version: 0.20.24787 (Git)
Hash: ea96f1860164ff8a6751b21b3fb4d425fc87f5e5
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
Align tilted face to front view (Solved)
- papyblaise
- tréteau.FCStd
- (124.59 KiB) Downloaded 29 times
- plan en biais.PNG (8.53 KiB) Viewed 1747 times
Re: Align tilted face to front view
I use one of the two view alignment macros I found in Addon manager to align the camera, then add the view to TechDraw.
In draft make a custom view to the face you want
Open the plane menu
Select center view
Now the view is good for the normal Techdraw operation
Open the plane menu
Select center view
- papyblaise
yes it's a solutionIn draft make a custom view to the face you want
thks
Re: Align tilted face to front view (Solved)
FWIW these are two macros I referred to:
Align to face macro:
https://wiki.freecadweb.org/Macro_Align_View_to_Face
Align Camera:
https://wiki.freecadweb.org/Macro_Align ... king_Plane
Align Camera:
- papyblaise
thks it's solved
I was just completing the comment I made earlier, since I didn't include the names of the macros I referred to.
Does it matter if this thread has multiple ways to answer the question?
I know this is solved but I wanted to add; If you go to settings and uncheck Preferences-Sketcher-Display "Restore camera position after editing". You can then click on any face of a model and click create a sketch, sketcher will rotate normal to that face and then you can then just exit sketcher. Because the option above is unchecked the screen will stay Normal to that face selected. You can then go to TechDraw and get Normal dimensions.
Thank You freedman for the Preferences-Sketcher-Display hint. My life just got a good bit easier.
