How to extrude certain parts?
cowmegalul
Postby cowmegalul » Tue May 18, 2021 4:27 am
I'm having trouble figuring out how to extrude the borders of my model.
The model I have is a keyboard top-down and I'm trying to figure out how to get the borders of the model and the plate of the keyboard to extrude.
Is it possible to have the frame of the keyboard and the plate as the keyboard as two separate entities to extrude?
I want to extrude the frame of the keyboard and the plate of the keyboard after. The model has blockers that are part of the frame of the case which I would want to extrude simultaneously.
How do I approach this?
Thanks!
(blockers connect to the frame, they are part of the frame).
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
blocker reference
blocker reference
prototype2.FCStd
(316.98 KiB) Downloaded 9 times
freedman
Re: How to extrude certain parts?
Postby freedman » Tue May 18, 2021 4:52 am
I think you will get more help if you simplify your example. How about drawing some kind of box or box top and put one or two holes in it, then ask some basic questions.
Postby chrisb » Tue May 18, 2021 5:39 am
For an extrude into a solid you need a closed set of lines without intersections, without T-joins. It can contain at most one inner such loop.
You have a set of single lines and I would recommend to create a sketch from all the lines you need and use this as a master sketch. Use the Sketch validation tool to connect the open vertices. Then clean the sketch with the trim tool. Replace unnecessaryly divided lines by single ones.
Then use this master sketch with carbon copy for you separate extrudes. You can quickly remove unneded lines.
thomas-neemann
Postby thomas-neemann » Tue May 18, 2021 7:44 am
cowmegalul wrote: Tue May 18, 2021 4:27 am
if i understood you correctly, that could be a solution
https://www.youtube.com/watch?v=SlLkdyfFKn0
phpBB [video]
falls ein video-link von mir schwarz und nicht anklickbar sein sollte, hier der kanal: https://www.youtube.com/channel/UCVcztV ... 03GgKekj_g
es ist auch möglich auf antworten zu klicken um den link zu sehen.
cowmegalul
Postby cowmegalul » Tue May 18, 2021 9:18 pm
Yes, that solution works. Thanks very much!
