Vertex or points above all and hide axis in Sketcher
jtm2020hyo
Postby jtm2020hyo » Tue May 18, 2021 11:29 am
I found a annoying problem using Sketcher, vertex and pointa are very hard to selecting and there I did not find option to hidde the axis when my line in below.
Is there a way to hide axis and do points more easy to selecting?
thomas-neemann
Re: Vertex or points above all and hide axis in Sketcher
Postby thomas-neemann » Tue May 18, 2021 11:40 am
jtm2020hyo wrote: Tue May 18, 2021 11:29 am
can you upload a tetst file (here I can easily select all points)
falls ein video-link von mir schwarz und nicht anklickbar sein sollte, hier der kanal: https://www.youtube.com/channel/UCVcztV ... 03GgKekj_g
es ist auch möglich auf antworten zu klicken um den link zu sehen.
drmacro
Postby drmacro » Tue May 18, 2021 12:19 pm
jtm2020hyo wrote: Tue May 18, 2021 11:29 am I found a annoying problem using Sketcher, vertex and pointa are very hard to selecting and there I did not find option to hidde the axis when my line in below.
Edit>Preferences>Display Pick radius and Markersize.
My beginners, written treatise: Learning FreeCAD
Roy_043
Postby Roy_043 » Tue May 18, 2021 2:45 pm
I suspect the OP is looking at the sketch from the bottom.
Syres
Postby Syres » Tue May 18, 2021 2:52 pm
If I need to select a vertex with the sketch not perpendicular then I use box select, it works even when the user is viewing the sketch from the back.
jtm2020hyo
Postby jtm2020hyo » Tue May 18, 2021 6:05 pm
thanks for suggestion, I was looking since bottom as metioned @Roy_043, I did not noticed that the reverse have a different view style, probably is not is not documented because I did not found anything relate in the internet.
