Creating timber floor joists from a sketch wire 2D diagram
Bance
Re: Creating timber floor joists from a sketch wire 2D diagram
Post by Bance »
paulgill28 wrote: Thu May 20, 2021 11:20 am Can you explain further what you mean by "And for heavens sake don't go modelling the lot use the symmetry that's there."?
There are three lots of joists in 30 degree intervals model one of them, then array the other two. Add the odd extra one at the end. :D
Note the joints aren't correct, it's to do with centre lines. I leave you to fix. I've used some Expressions, and Sketcher_CarbonCopy for sketches.
patio.FCStd
(227.36 KiB) Downloaded 13 times
domad
Post by domad »
Good evening to the Community!
.... another alternative workflow (with beveled floor)
Perimeter wall with wire sketch for garden room base.FCStd
(236.26 KiB) Downloaded 19 times
paulgill28
Post by paulgill28 »
Bance
Many many thanks for your help. I will look into what you have posted. Sorry for the delay in replying. Life gets busy.
Cheers
Paul
paulgill28
Domad
Thanks for your post. I will investigate.
Paul
paulgill28
It never would have occurred to me to use a pad and pockets. Very clever.
There always seems to be more than way to achieve ones goal in FreeCad.
Thanks again.
