https://github.com/aep/kicad/raw/master ... m-min.step
I am trying to further simplify it as my computer struggles with it when used in another project. I think it is because of all the little round balls under the "BROADCOM_BCM2711" and the `SAMSUNG_KLM4G1YE4C-B00X` items in the tree, like this: I have tried two methods and neither is successful:
1. Create a box in the `Part` workbench, position it with the Draft move (with snap enabled). Then perform a boolean cut: It creates a `cut` object. I then delete the original item (because I am trying to reduce the filesize/complexity), but then everything breaks. I try to export it as a step file and then FreeCAD closes.
2. I found an icon that "Explode Compound". This seemed perfect in that I could then select the "BROADCOM_BCM2711", explode it, then try delete the sub parts which are the balls. However "Explode Compound" once again makes a ouput that is dependent on the original. I just don't seem to be able to delete something so it can be simple without creating a more complex version.
What is the correct work flow to trim a step file?
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
