may I export as image?
confrey
Postby confrey » Sat Feb 22, 2014 2:43 pm
Hi everybody again
OS: Linux Mint 16 Petra
Platform: 64-bit
Version: 0.14.3167 (Git)
Hash: bb98b5afb0890d786da88aaf8dc8bf05872c5d7a
Python version: 2.7.5+
Qt version: 4.8.4
SoQt version: 1.5.0
OCC version: 6.7.0
how may I save a bitmap image of model I'm building?
thanks
jmaustpc
Re: may I export as image?
Postby jmaustpc » Sat Feb 22, 2014 2:48 pm
two common ways are either tools menu "save picture" which saves a jpeg file of the current view in the model window or use a screen capture application which can take a picture of anything displayed on you screen.
Note that the first one only works if your GPU and its driver support it. Most should, but some pathetic old GPUs do not and some drivers may not implement the feature even when the hardware would.
bejant
Postby bejant » Sat Feb 22, 2014 4:05 pm
Tools -> Save Picture also allows you to save the image in a number of other formats too (one of which is .bmp).
confrey
Postby confrey » Sat Feb 22, 2014 5:34 pm
many thanks
foadsf
Postby foadsf » Wed May 29, 2019 7:24 pm
strangely enough, I can't export any of the options
  • [ * ] PDF: from File > Export PDF ...
    [ * ] SVG: from File > Export > Save as types: Flattened SVG (*.svg)
    [ * ] image: from Tools > Save picture ...
The image is completely black, PDF is empty and SVG is a weird decomposition of what I have. Please find the file in the attachment.
model.FCStd
(4.72 KiB) Downloaded 224 times
My FreeCAD environment is:
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
openBrain
Postby openBrain » Wed May 29, 2019 8:27 pm
Can you please tell what is your GFX card model?
Postby chrisb » Wed May 29, 2019 9:05 pm
Can you create a TechDraw page and export that as a PDF with File->Export PDF?
The other tools are probably all have the same basis, which can fail due to graphics card or driver issues.
foadsf
Postby foadsf » Thu May 30, 2019 12:19 pm
running the command:
wmic path win32_VideoController get name
I get
Intel(R) HD Graphics Family
NVIDIA GeForce GT 735M
and regarding the
The File->Export PDF of TechDraw page seems to be fine.
test.pdf
(210.66 KiB) Downloaded 248 times
Postby chrisb » Thu May 30, 2019 12:40 pm
So it is most probably a driver issue. You can try upgrading (or downgrading).
foadsf
Postby foadsf » Fri May 31, 2019 2:38 pm
any other solution not requiring messing up with the drivers? Windows drivers are really annoying to manage.
