3D arrows when using transform
i am trying to transform an imported step file position to align in my body. the issue i have is the step file object origin is not center to the object so unless i zoom out, i can not see the transform arrows this makes it almost impossible to place the object. i cannot seem to move the objects origin to the center of the object either
OS: Windows 10 Version 1909
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
There is no Gravity....Taxes Suck!
Re: 3D arrows when using transform
This is a known issue. I recommend:
- hover over the objects edges/vertices and note the coordinates in the status bar at the bottom
- edit the Placement property in the Data tab.
- change the values to the inverse of the coordinates seen before.
I'd like to discuss this a bit.
I just opened a Step file with the following: Note: it has 4 components. Deleting the 2 components that form the motor housing reveals the envolutes are not at global 0,0,0.
If I now select one of the envolutes and open the Edit>Placement dialog it is seen the the X,Y,Z values, as expected, not 0. The point of this is to get them at 0,0,0, I simply set these value to 0 and click Ok.
And the component is now at 0,0,0 (The Placement property confirms this.) Is there a special situation here that means the inverse of the values aren't required to move it to global 0,0,0.
Side note: Can't drag the component directly to a Body. It needs to be dragged out of the Std_Part, then into the Body to get a BaseFeature.
THe STEP file: C38-81.STEP here: https://www.thingiverse.com/thing:4073910/files
Yes.drmacro wrote: ↑Mon Jun 07, 2021 1:35 pm
The global coordinate system is that of the document. Inside this document you have C38-81. If you look at C38-81's placement within the document it has displacement zero and rotation zero - that is its coordinate system is coincident with the global one. The placement is the identity transformation.
Inside C38-81 you have the envlouts - their placements are relative to their container, which is C38-81, which in this case is the same as the global system.
So setting the placement of the envlouts to the identity, in this case, is the same as applying the inverse of the global placement, because their container object's coordinate system happens to be the same as the global one.
If C38-81's placement had not been the identity, this would not have worked.
https://wiki.freecadweb.org/Sandbox:Edw ... #Placement attempts to clarify all this.
So, you are saying the placement of the container of the step file in the OP was NOT at the global identity?
No, I said the opposite. You asked if there was a special situation that made your method work. I replied yes - because the global placement of the container of the STEP file WAS the identity. If this hadn't been the case, it wouldn't have worked.
Maybe I phrased this whole discussion wrong. (And, I'll state I need to read your sandbox again, slowly...)edwilliams16 wrote: ↑Mon Jun 07, 2021 7:14 pmNo, I said the opposite. You asked if there was a special situation that made your method work. I replied yes - because the global placement of the container of the STEP file WAS the identity. If this hadn't been the case, it wouldn't have worked.
My quandary is, I don't think "use the inverse" is a blanket cure all and needs some further explanation.
Or maybe I'm just slow on the uptake...
Agreed. I think we have wandered away from the OP to a more generic issue. The global position and orientation of the origin of some object depends on the entire chain of coordinate transformations between it and the global system of the document. Changing any one of those placements, attachments or attachment offsets changes the positions of all the objects below it in the tree. The choice of which placement to adjust to achieve some desired result depends at what level in the tree you would like to maintain the relative position of other objects. Part containers and their placements give you an explicit way of grouping objects for this purpose.
It's all computable from the placements and perhaps their inverses once you know exactly what you are trying to achieve. In my sandbox, I consider the example of making a given change in the global placement of an object by adjusting any one of the placements in the chain from the object to the root document. There seemed to be a number of questions in the Forum that boiled down to that.
This may or may not address your question, and likely tells you what you already knew.
As a new to freecad user , your answers have gone way past me.
i will try to ask using photo trickery. lol
this is what i see when i select a step for transform
this is what i want to see
This is the file
https://grabcad.com/library/2-way-banana-plug-jack-1
This is the file
This is not possible at the moment. The reason is, that the transform tool is always placed in the center of the object, which obviously is not the center of mass.
Think of it like a sketch, where you draw a rectangle far of the center and pad it. Then the Transform tool would still be placed in the center of the sketch.
