3D arrows when using transform
thomas-neemann
Re: 3D arrows when using transform
Post by thomas-neemann »
HtRabbit wrote: Thu Jun 10, 2021 2:22 am
......this is what i want to see...
this is possible with draft (move with draft)
https://www.youtube.com/watch?v=vgg5aB9o6oM
phpBB [video]
hpbmo
Post by hpbmo »
Hi
I have very often the same problem with step or stl files with the origin far away form the freecad origin. With folowing workaround can I replace the step model to the origin.
First center the model with the Manipulator WB. Select the desired face witch you want to have on the origin.
Replace it with the align tool from Manipulator WB
Now with Part WB make a compound and from the compund a simple copy
The copy is now placed as you may wanted. The nice colors get lost and if you don't need the single parts this would be an easy way to replace the plug to the Freecad origin.
Hope this helps
hpbmo
Pauvres_honteux
Post by Pauvres_honteux »
hpbmo wrote: Thu Jun 10, 2021 6:33 am I have very often the same problem with step or stl files with the origin far away form the freecad origin. With folowing workaround can I replace the step model to the origin.
Could this be automated (=fewer clicks and streamlined) and transformed into a feature request?
drmacro
Post by drmacro »
Pauvres_honteux wrote: Sat Jun 12, 2021 7:54 am ...
You clearly have not been following this thread: https://forum.freecadweb.org/viewtopic. ... t=59269
:mrgreen:
edwilliams16
Post by edwilliams16 »
Try out the following macro. https://forum.freecadweb.org/viewtopic. ... 30#p509997
HtRabbit
Post by HtRabbit »
well i cheated. took the file to fusion 360 and opened it there, did a move/translate to xyz origin (less than 5 minutes)...export step and import in to freecad.
while this did work there really should be an easier way in freecad. I really want to get away from fusion 360 completely
freecad origin transform5.png (120.61 KiB) Viewed 1333 times
https://drive.google.com/file/d/1-T8Gb1 ... sp=sharing
There is no Gravity....Taxes Suck!
HtRabbit wrote: Sat Jun 19, 2021 5:49 am while this did work there really should be an easier way in freecad.
Following the forum, there is everyday something to learn. In this case it's edwilliams' macro: https://forum.freecadweb.org/viewtopic. ... 97#p510397
HtRabbit
Post by HtRabbit »
sadly that macro did not work for me
i also found that opening it in "Matter Control" place it at orgion and exporting it worked as well
edwilliams16
HtRabbit wrote: Sun Jun 20, 2021 8:24 pm sadly that macro did not work for me
What didn't work? How did you attempt to use it? Make sure you have the most recent version: https://wiki.freecadweb.org/Macro_MoveToOrigin
