all sharp edges need to be rouded
- mwlandolsi
could any one help me how to round all sharp edges in this tank (blow moulding)
https://drive.google.com/file/d/123d6lM ... sp=sharing
Re: all sharp edges need to be rouded
Filleting is problematic if vertices are involved, where four or more edges meet; even more so if there are sharp angles. You can try different sequences of filleting or change the sequence of how you build your model.
- papyblaise
Several things make the process complex
the shapes intersect and produce common edges
some shapes are created with loft, which is practically impossible to fillet
by making a big cube then cutting with pockets I manage to put rays everywhere except vertically, and the workaround is to make a cube with radius angles and make a common (which only works in Part)
the objective of a container is to be empty otherwise it is a brick: I cannot manage to do it
I think we will have to make separate objects: the body and the top and merge them
and also add the handle
in the attached file, the common is not done because of the file size
- bidon1.FCStd
- (918.59 KiB) Downloaded 28 times
- bidon1.PNG (41.31 KiB) Viewed 1631 times
- mwlandolsi
Thanks to @papyblaise and @chrisb for your ansewers .
Could you please @papyblaise tell me which version of freecad you are using to create this, because when I opened with my downloaded version, I go error
I used this
OS: KDE Flatpak runtime (X-Cinnamon/cinnamon)
Version: 0.19.14555 (Git shallow)
Python version: 3.8.8
Qt version: 5.15.3
and the error was : SketchObject::onChanged(): Unmanaged change of Constraint Property results in invalid constraint indices
and by using
OS: Linux Mint 20.1 (X-Cinnamon/cinnamon)
Version: 2021.531.24301 +3702 (Git) AppImage
Branch: LinkDaily
Hash: 4ad819f55a108b7e8bddb134d0de39218e662aa4
Python version: 3.8.10
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.4.0
I got this :
Sketcher constraint number 15 is malformed!
22:52:36 Sketcher constraint number 16 is malformed!
22:52:36 Sketch Sketch001 has malformed constraints!
22:52:36 Recompute failed! Please check report view.
22:56:25 Sketcher constraint number 15 is malformed!
22:56:25 Sketcher constraint number 16 is malformed!
22:56:25 Sketch Sketch001 has malformed constraints!
22:56:25 Recompute failed! Please check report view.
I used this
Qt version: 5.15.3
and by using
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.4.0
I got this :
- papyblaise
OS: Windows 10 Version 2009
Version: 0.20.24787 (Git)
Hash: ea96f1860164ff8a6751b21b3fb4d425fc87f5e5
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- papyblaise
I have several additional questions concerning the generation of tichness towards the outside
-is it possible to change the connection radius of the external walls (by default it is equal to the generated thickness)
-is it possible to also generate an interior ray
-is it possible to generate an object whose interior volume will be larger than the base volume to somehow make an offset at the same time
- mwlandolsi
Hello @papyblaise,
It seems that there is no possibility to change the radius of the outside wall.
But what i have done is :
create a thin function with the desired radius and of curse it will be a thick object. for example 4mm
then create a clone of the non thick body (just before you create the thick wall) with a thickness just less than the first thickness by the desired final thickness. (for example 3 mm to get final thickness of 1mm) Finally create a boolean cut between the tow bodies. you will get the desired outer radius (4mm) and the desired wall thickness 4-3=1mm).
here is what I got with another design of tank.
Hello,mwlandolsi wrote: ↑Thu Jun 10, 2021 9:58 am could any one help me how to round all sharp edges in this tank (blow moulding)
I did a lot of tests in PartDesagn WB, then Part WB, with several construction techniques. I noticed one thing: When using Loft, the created edges have difficulty accepting the fillets.
Important note: I have modified some details of the shapes to avoid the "unfortunate coincidences" which prevent you from succeeding with the fillets.
So I tried a PartDesign version only with Pads and Pockets, and I got clear progress.
Finally I tried the LinkBranch version of Realthunder: I had the pleasure of discovering that the copy by symmetry also copied the leaves!
Here is the result, and above all it is fully obtained in PartDesign WB :
The file :
https://www.dropbox.com/s/yzyduym0in4ac ... FCStd?dl=0
My website : http://help-freecad-jpg87.fr updated 2023/11/06
- mwlandolsi
Yes it looks better, I have noticed the same problem too with the fillets. The next challenge is how to make it thin. This function also requires some attention to the edges. They should be spaced enough to create fillets. Especially in outside thickness mode.
Another approach.mwlandolsi wrote: ↑Wed Jun 16, 2021 2:48 pm Yes it looks better, I have noticed the same problem too with the fillets. The next challenge is how to make it thin. This function also requires some attention to the edges. They should be spaced enough to create fillets. Especially in outside thickness mode.
0.7 mm wall (beyond that it no longer works).
Obliged to cut the opening if not pb.
Copy to Part WB for easy symmetry, then Union.
The file :
https://www.dropbox.com/s/8lyphemqq92rs ... FCStd?dl=0
