0.19 Align, scale, position Text to a skewed surface
Please Note:
I already downloaded the 3D text addition of Freecad.
I created a model.
(A sphere subtracted from a cube)
I want to add multi-line text to one of the surfaces of that cube.
(later I want to add an imported logo to the other surfaces, but that's another project)
What I can do:
1) I can create the text.
The problem is the model's surface is skewed to the DRAFTING PLANE (I need to align the Drafting-Plane to the surface of the cube).
I can move the text in X,Y,Z but when it updates, the text is rotated somewhere out in space (never works... ever!).
I've watched a few vid's on extruding text onto surfaces, but the are ALWAYS on the same plane as the surface, mine isn't.
What I can't do:
1) Reposition the text onto the surface I want it on.
2) Scale the multi-line text to the size I need.
Thanks,
BS
I created a model.
What I can do:
What I can't do:
Thanks,
BS
Re: 0.19 Align, scale, position Text to a skewed surface
Have you read this?: Draft_ShapeString_tutorial
Not sure if this helps, but I guess the text behaves similar to a ShapeString: You can try to attach the text to the plane, or - even more robust - to some underlying non generated geometry.
Thanks Roy_043!
I watched the video on youtube a few weeks ago, but forgot about it.
I did however try to find something in "Help", but I got everything else but what I was looking for (then tried this forum).
I'll follow along the tutorial, then try my text & object again.
1 question though.
I see the tutorial creates the text as a solid 1st, then moves the solid text object.
I have an image, converted into a shape that I can't seem to rotate on a datum-line I added to do that with.
Is that similar to the text-object for positioning & rotation?
Thanks,
BS
1 question though.
Thanks,
BS
Here is a simple Part cube to which I attached the text. Which workbench do you use?
- textAttached.FCStd
- (4.47 KiB) Downloaded 15 times
The text is on the top-plane (xy).
I can't seem to rotate that text to another surface.
Is there a tutorial that shows how this is done?
I have the same problem with a sketch of an image, can't seem to rotate it to the desired plane...
That sketch can be extruded, but I want to project it like I did my text, onto a round surface.
Thanks,
BS
Thanks,
BS
You should work through the Basic Attachment Tutorial.
Another way is to simply create the ShapeString, drag it into the Body and attach it to the XY_Plane, and Pad/Pocket.
Just another option.
Thanks for the help people!
I finally found how to aligned anything I create (objects, solids, text... ect).
Using the Placement (angle, axis & position).
I'm very capable in AutoCAD writing code in both 2D & 3D, but Freecad seems a bit confusing to me trying to adjust something to the place I need it.
I will go through the Basic Attachment Tutorial.
Thanks Again...
BS
Thanks Again...
BS
