To create text
heda
Re: To create text
Post by heda »
one user improvement could be to at least make an attempt to search typical font-dirs on the various os's,
or at least raise an infobox or something, that there is no font to make text with, if not a path is provided.
that should be fairly easy to code even for a complete beginner (python in draft, and suppose it's a one liner to raise a infobox in pyside),
so let's see who is the one to pick it up :-).
Roy_043
Re: To create text
Post by Roy_043 »
There is a parameter 'Default ShapeString font file'. IMO we should first check why this does not receive a usable default value.
drmacro
Re: To create text
Post by drmacro »
Roy_043 wrote: Sun Jun 13, 2021 6:07 pm There is a parameter 'Default ShapeString font file'. IMO we should first check why this does not receive a usable default value.
My first guess it that there is no one font file that can be expected to be resident on all platforms...
But, that is just a guess. :mrgreen:
Re: To create text
drmacro wrote: Sun Jun 13, 2021 7:31 pm My first guess it that there is no one font file that can be expected to be resident on all platforms...
You are probably right, Courier could be a candidate though. But I think anyway that it would be better to open the file selection box with preselection to fonts if no font file is selected.
drmacro
Re: To create text
Post by drmacro »
I agree, some attempt would be nice. I know remembering the path to the font directory is top most in my mind...not. :lol:
Roy_043
Re: To create text
Post by Roy_043 »
Qt and Coin do manage to grab fonts from the OS. So technically it is possible. A Draft_Text (Coin based) can be created without specifying a font file for example. From the perspective of the end user it is hard to understand why the same does not apply to Draft_ShapeStrings (not Coin based).
Roy_043
Re: To create text
Post by Roy_043 »
Matplotlib to the rescue?:
from matplotlib import font_manager
print(font_manager.findfont("Arial"))
print(font_manager.findfont("Sans"))
Note: slow when used for the first time.
snowforest
Re: To create text
Post by snowforest »
The fonts were at:
C:/WIndows/Fonts
I use the current windows version
I was able to type the text . Thanks
mario52
Re: To create text
Post by mario52 »
Hi
if you have problem or difficult tray Macro_Fonts_Win10_PYMP Image just for see or testing
mario
Accessdenied
Re: To create text
Post by Accessdenied »
Hi!
I need to extrude the text from the cylinder. Tried to use this instruction: https://www.youtube.com/watch?v=fGCkKdXUBZU
Draft the text, make a projection and then cut it with bolean. But the problem is, that if text is too long, then projection on such cylinder is very deformed, how can I make a text to be projected perpendicularly to the cylinder not like projection from one side?
