Extruding Multiple Wires Together
duckmug
Post by duckmug »
Lets say that in the draft workbench I create a rectangle wire and I draw a circle wire in its center.
Is there a way that I can extrude both in a similar way to sketching so that the circle gets interpreted as a hole?
I came across the post of someone that selecting both wires, upgrading (creating a compound) and extruding would do that, but it doesn't, it instead extrudes both as solids.
Re: Extruding Multiple Wires Together
Why don't you do it in Sketcher?
duckmug
Post by duckmug »
To be entirely honest, the fact that I have to be adding tens of constraints every time seems problematic to me.
I totally understand the benefits of it but it's time consuming.
drmacro
Post by drmacro »
duckmug wrote: Sat Jun 12, 2021 11:47 pm To be entirely honest, the fact that I have to be adding tens of constraints every time seems problematic to me.
So don't add constraints.🤷‍♂️
Your model won't be parametric...but, then it won't be in Draft workbench either. :mrgreen:
I don't know what you want to model, but precision takes its time. Either by using such things as constraints or by doing some math outside of FreeCAD.
duckmug
Post by duckmug »
I am coming from code-based CAD tools where making designs parametric was a piece of cake, so I am exploring my options for different use cases.
heda
Post by heda »
extrusions are done per face,
so if you make your rectangle and circle with the property "make face" set to true it becomes quite clear why fc does 2 extrusions from the compound (even more clear if you downgrade that compound).
now the question is, how does one make a face with a hole in it?
2 different ways:
draft/rectangle + draft/circle -> part/cut
draft/rectangle + draft/circle -> draft/upgrade (now a compound) -> part/bool xor
ps: when you are tinkering around in draft you are at the same time automatically learning a bit of the lower levels of fc, and how things work in terms of building different geometries, that learning will always be useful also somewhere else - so keep going your own way - but there might be a time when you yourself come to the conclusion that doing this in sketcher is best for you - but then at least it is your own finding, and not someone else's.
duckmug
Post by duckmug »
Very informative, thank you so much!
