Smart Circular Loop Face Select
I attempted searching for similar threads and came across something that mentioned holding down shift and selecting faces.
It doesn't seem to work. I want to basically be able to somehow easily select all those faces/triangles that are part of that same array.
The goal is to be able to easily add them to the defeaturing workbench list for further processing.
What would be the right way to do that?
- Screenshot from 2021-06-14 00-42-54.png (20.05 KiB) Viewed 1090 times
Re: Smart Face Select
Like in Blender...an actual native mesh modeler?
Have you tried the Mesh or Defeaturing workbenches?
Yes, in the defeaturing workbench, there is a list that I can press the add button and have the selected faces be added there.
My issue is how to quickly select all those triangle faces that are part of that same circular array so that I can get them in there.
If GUI can't help with this, a scripting workaround would also work.
Ok, I think I traced something that works very close, which is box selection, still not totally precise.
Would love to hear in case there's anything better that is particularly suited to circular loops of faces.
Re: Smart Circular Loop Face Select
I wanted to check, but FreeCAD crashes on two of the meshers, and the default looked quite different, so my question is, if defeaturing works after all. Does it create a conical shape, even if everything around is flat?
Yes defeaturing works fine here.
fc is probably the best cad system around to script in,
and a bit of python should really be possible for most people,
combine that with an ounce of determination to get things done...
an example of a slow and naive algo...
# select a face on a refined solid, originating from a mesh
# run macro, adds all adjecent faces to selection
from itertools import chain, combinations
s, = Gui.Selection.getSelectionEx()
obj = s.Object
selface, = s.SubObjects
selfacename, = s.SubElementNames
selfaceid = int(selfacename.replace('Face', ''))
print('Selected face: {} in {}'.format(s.ObjectName, selfacename))
Gui.Selection.clearSelection()
def xyz(vert):
return vert.X, vert.Y, vert.Z
def face_verts(face):
return (xyz(v) for v in face.Vertexes)
def common_vert(fa, fsv):
pairs = combinations(chain(face_verts(fa), fsv), 2)
return sum(i == j for i, j in pairs)
faces = obj.Shape.Faces
selfaceverts = tuple(face_verts(selface))
hits = list()
for i, face in enumerate(faces, start=1):
if i == selfaceid: continue
found = common_vert(face, selfaceverts)
if found:
hits.append('Face{}'.format(i))
Gui.Selection.addSelection(obj, hits)
print('ready')
Thank you so much, that is pretty handy!
Update: I tested it and it doesn't seem to select them in my case.
well, the code does what it does, not necessarily what you are after
it is just one example intended to illustrate that it is not that hard to script in fc,
it simply is one way to select adjacent faces.
could be coded differently, like using vector distances and still do the same.
feel free to tweak it to your own needs.
Yes I understand and appreciate your effort regardless, will try to play with it.
