What is the typical work flow for this example
Eric123
Post by Eric123 »
I'm just learning freecad and I would like to experiment a little with an existing model which was in .dae format that consists of multiple meshes. Here's what I'd like to do:
  • Modify the shape of some of the parts (curves, etc.)
  • Generate some tool paths for CNC
  • Eventually create some drawings with the techdraw tool
  • It would be nice to also move some of these meshes back to a 2d sketch for parameterization if possible
My understanding is I need to convert the meshes back to shapes or solids. I've tried analyzing and repairing the meshes, then converting them to shapes. However it runs for hours and nothing seems to happen. I've tried just converting one mesh to a shape and I have the same problem. I've tried adjusting the tolerance (allows 1-9 as values) but it doesn't seem to help.
I'm not sure what to do our how to approach this problem. Any suggestions or links to resources would help. I've attached the model I'm working with.
Thanks,
Eric
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
oc6-bradley.FCStd
(54.24 KiB) Downloaded 17 times
Re: What is the typical work flow for this example
Hi and welcome to the forum!
I used "Mesh" as an example. I repaired it in MashDesign workbench and conversion to a shape and from shape to solid was done in seemingly no time. Perhaps you need to update.
Please attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
OS: macOS 10.16
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.9.4
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
Eric123
Post by Eric123 »
Updated the post. Did you convert it to a shape after selecting all the meshes, then going to the parts workbench and using convert mesh to shape? That's where it just hangs for hours for me.
Eric123 wrote: Mon Jun 14, 2021 8:59 pm Did you convert it to a shape after selecting all the meshes, then going to the parts workbench and using convert mesh to shape? That's where it just hangs for hours for me.
I didn't convert all meshes, because you said you had the same problems when converting a single one. FreeCAD isn't optimized for working with meshes, so if one of the meshes has let's say far more than 100,000 triangles the conversion can take too much resources. You may check if there is one such mesh among them.
edwilliams16
Post by edwilliams16 »
Repairing Mesh006 hangs FreeCAD. The meshes are all bad - not uncommon - maybe you should run the collada file through an external repair service before trying to import it into FreeCAD.
Eric123
Post by Eric123 »
Thanks. I noticed that I could get some to run through but then large portions would be deleted after repairing. I'll try another tool to repair it, but it's probably going to need redrawing I guess.
