Sketch001 should be called MasterSketch :
* 3 dimensions come from the spreadsheet (check each expression) :
** the radius (RR)
** the width of teeth (WW)
** the angle (AA = 360°/NN /2 calculated in the spreadsheet) (NN = number of teeth)
* Other dimensions are just reference dimensions (color blue) but give name to :
** the length of the teeth (LL)
** the distance from the center (DD)
FC compute itself these 2 dimensions as the teeth must verify :
* be a rectangle
* 2 points on the circle
* symmetry along the vertical axe (= horizontal constrain)
* point on the 'angle' (blue line of reference)
Simple math can do the same job (trigonometry) but FC is a friend.
Sketch002 is for construction :
* width (WW)
* the sketch has a z-offset of DD [×(-1)] value (Data>Attachment Offset>Position>Z)
Pad001 use LL
help Array Pollar
- Shalmeneser
Re: help Array Pollar
Here is a PartDesign solution based on Willem's model.
A problem is that the overlap detection mode doesn't work. If I set it manually to overlap, it works. David, you have implemented this optimization; care to have a look?
davidosterberg wrote: pinged by pinger macro
- PRISM-GEAR_cb.FCStd
- (296.24 KiB) Downloaded 8 times
