Sketch Mapping And Origin
duckmug
Postby duckmug » Tue Jun 15, 2021 8:28 pm
I am slightly confused with something. Say I create a new sketch and draw what I want around the origin.
I can easily create symmetry and other things because it's centered around point 0 and I can relate it with the axis etc. So far so good.
Then I want to map it to a very specific point on the face of the body.
You can see the attached photo.
I suspect that moving the sketch placement in order to map it is not the right approach.
I saw some using datum planes but I also saw others recommend against it.
So what is the ideal way to create the sketch around point 0 / origin, relate it with the axis etc and then map it exactly on a specific area on a face of the body?
Screenshot from 2021-06-15 22-52-56.png (9.1 KiB) Viewed 217 times
Shalmeneser
Re: Sketch Mapping And Origin
Postby Shalmeneser » Tue Jun 15, 2021 9:34 pm
You need to provide a specific example.
Postby chrisb » Tue Jun 15, 2021 10:01 pm
Placing something on generated geometry such as a face is not a good idea due to the topological naming problem.
Another stable solution is - besides placing everything on the main planes - to use references to sketches and using expressions.
Bance
Postby Bance » Tue Jun 15, 2021 10:43 pm
duckmug
Postby duckmug » Tue Jun 15, 2021 10:49 pm
chrisb wrote: Tue Jun 15, 2021 10:01 pm Placing something on generated geometry such as a face is not a good idea due to the topological naming problem.
Arather stable solution is - besides placing everything on the main planes - to use references to sketches and using expressions.
Thanks a lot, very insightful. I will avoid doing that from now and on and do according to the guide.
