I have one little problem cutting in sweep forms. When I subtract one form from the sweep it will crack.
Here are before cutting. The cone should be cut off.
After the sweep helicx are destroyed.
How can I fix this?
/PelleH
Cutting in sweep destroys part
- papyblaise
Re: Cutting in sweep destroys part
it is often only a visual defect, if you do a subtractiv pipe, in general it works
but without file, no definitive answer
Here are two files. Helix.FCStd,
, are before boolean cut and Helix2.FCStd, , are after boolean cut.- Attachments
- Helix2.FCStd
- After cut
- (32.96 KiB) Downloaded 13 times
- Shalmeneser
The same problem in the french forum : https://forum.freecadweb.org/viewtopic.php?f=12&t=58660
FreeCAD is parametric, so it's sufficient to upload one of the files instead of three.
It works in PartDesign. We have seen this before, that the helical sweeps behave differently in both workbenches.
- Helix_cb.FCStd
- (75.35 KiB) Downloaded 11 times
Thanks, Part Design did it.
